injector o-rings EmptyWed Oct 19, 2022 1:27 pm by scot
injector o-rings EmptyTue Oct 18, 2022 8:58 pm by silverfox103
injector o-rings EmptyTue Sep 28, 2021 11:01 pm by silverfox103
injector o-rings EmptyFri Sep 24, 2021 9:53 am by ElKy
injector o-rings EmptySun Sep 19, 2021 6:22 pm by black blur 96
injector o-rings EmptySun Jun 20, 2021 11:37 am by scot
injector o-rings EmptyFri Jun 11, 2021 10:41 am by scot
injector o-rings EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
injector o-rings EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
 injector o-rings
2 posters
soshoresig
PostSubject: injector o-rings   injector o-rings EmptyWed Sep 14, 2011 3:40 pm
So I replaced a leaky injector on my son's 96 SS and when I put the fuel rail back on fuel sprayed out of the top of 2 other injectors at the rail. I took it back apart and the two injector orings had split. I picked up a set of 8 o-rings and they seem to be a different color (material)?? Is there a right and wrong way to put the rail back on? I left the injectors in the intake, put the o-rings on the top of the injectors and pushed the rail down onto the injectors, then sequentially tightened the 4 rail hold down bolts. Is there a better way? Should I lube the o-rings?
Thanks for any and all help
Grumpy
PostSubject: Re: injector o-rings   injector o-rings EmptyWed Sep 14, 2011 8:41 pm
I lube them an make sure they are sliding in the intake and the rail.. I goop the rail and the intake to.
soshoresig
PostSubject: Re: injector o-rings   injector o-rings EmptyFri Sep 16, 2011 8:29 am
thanks, new,lubed orings went right in no leaks. but now...
injector o-rings
» Help with opti O-rings
» New trim rings for sale
» Center caps and trim rings for civi wheels?
» no injector pulse
» Injector diffrences
