The RIGHT way to do pads EmptyWed Oct 19, 2022 1:27 pm by scot
The RIGHT way to do pads EmptyTue Oct 18, 2022 8:58 pm by silverfox103
The RIGHT way to do pads EmptyTue Sep 28, 2021 11:01 pm by silverfox103
The RIGHT way to do pads EmptyFri Sep 24, 2021 9:53 am by ElKy
The RIGHT way to do pads EmptySun Sep 19, 2021 6:22 pm by black blur 96
The RIGHT way to do pads EmptySun Jun 20, 2021 11:37 am by scot
The RIGHT way to do pads EmptyFri Jun 11, 2021 10:41 am by scot
The RIGHT way to do pads EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
The RIGHT way to do pads EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
4 posters
PostSubject: The RIGHT way to do pads   The RIGHT way to do pads EmptyThu Apr 28, 2011 11:04 am
When an online parts vendor sends me an email I usually open & review briefly.
If there's anything that catches my interest, I go further, if not ...delete.
I just grabbed some pads @ AZ for Matts car (I'm buttoning it up) so when I saw the pads link I checked it out.
I clicked the "How to install brake pads" & thought I might share it with you.
I've been wasting so much of my time doing it MY way
Here's thier method.....
Installing Brake Pads on Your Vehicle
Once you’ve purchased your new brake pads from AutoAnything, you’ll want to make sure you know how to install brake pads on your ride.
Don’t succumb to the high labor cost at the local body shop when you can install your new brake pads yourself.
Brake pads installation is easy to complete, and simply requires the use of common tools, like an open-ended wrench, an Allen wrench, a lug wrench and a hammer.
After you’ve jacked your vehicle up and removed the wheel, you’ll need to remove the brake caliper so that the brake pad will slip right out through the top.
The brake pad should slip out easily, although you may need to coax it out with a hammer.
Once the old brake pads removed, slip your replacement brake pads into place.
You’ll need to compress the brake piston and then you can easily slide the brake caliper assembly over the new brake pads.
Replace the bolts, put your wheel back on, and your ride will be ready to go—or should I say, stop?
No need to thank me.......yes, I'm a little bored right now
PostSubject: Re: The RIGHT way to do pads   The RIGHT way to do pads EmptyThu Apr 28, 2011 11:44 am
I think that would work for about none of the cars that I have worked on...ever. It does work on a Polaris snowmobile though....
onehunglo
onehunglo
PostSubject: Re: The RIGHT way to do pads   The RIGHT way to do pads EmptyFri Apr 29, 2011 7:19 am
I always bed my pads as well.
PostSubject: Re: The RIGHT way to do pads   The RIGHT way to do pads EmptySat Apr 30, 2011 7:22 am
do brakes really need instructions?
» New Rotors and Pads are on the way!
» front hawk pads
