| ENGINE BAY CLEANING!!!!! | |
+6waynes91 GasTT toomanytoyz Fishah JRS9C1 BoSStonsSS 10 posters |
| Subject: ENGINE BAY CLEANING!!!!! Mon Mar 30, 2009 3:12 pm | |
| WHATS THE BEST PRODUCTS TO CLEAN THE ENGINE BAY?
AND
WHAT TO COVER SO NOTHING WILL GET RUINED?
POST PICS ALSO IF YOU WANT TO OF BEFORE AND AFTER
THANX | |
JRS9C1
| Subject: Re: ENGINE BAY CLEANING!!!!! Mon Mar 30, 2009 3:38 pm | |
| Lots and lots and lots of armor all wipes? | |
| Subject: Re: ENGINE BAY CLEANING!!!!! Mon Mar 30, 2009 4:54 pm | |
| No. Not armor all wipes. You can pretty much hose down the whole engine bay with low pressure. | |
| Subject: Re: ENGINE BAY CLEANING!!!!! Mon Mar 30, 2009 5:40 pm | |
| Cheapo way? Spray cold engine with Windex. All over. Hose off. Done. Yes, I'm serious. | |
| Subject: Re: ENGINE BAY CLEANING!!!!! Mon Mar 30, 2009 7:21 pm | |
| Clean everything individually with terrycloth towels and a degreaser. Use steel wool on the aluminum parts. I used this Black magic engine cleaner/shiner once and it worked awesome. You soak your engine bay with it and then put water in a spray bottle spray and wipe.
http://www.blackmagicshine.com/products.aspx/58/black-magic-2-in-1-engine-shine
I recommend this product. | |
| Subject: Re: ENGINE BAY CLEANING!!!!! Mon Mar 30, 2009 8:19 pm | |
| - GasTT wrote:
- Clean everything individually with terrycloth towels and a degreaser. Use steel wool on the aluminum parts. I used this Black magic engine cleaner/shiner once and it worked awesome. You soak your engine bay with it and then put water in a spray bottle spray and wipe.
I recommend this product. so did u clean everything frist then sprayed with bms, or did u use bms by itself, how did it work on aluminum, would it damage the paint? | |
| Subject: Re: ENGINE BAY CLEANING!!!!! Mon Mar 30, 2009 10:13 pm | |
| I just used that stuff I didn't clean anything first. It does nothing to paint. Not sure how it works on aluminum I used it on a 3800 series II. | |
| Subject: Re: ENGINE BAY CLEANING!!!!! Tue Mar 31, 2009 1:06 pm | |
| There's no way I'm the only one who figured out the tricks.
Paint everything black and then don't open your hood often. It works great for me. Then occasionally I spill oil or something on stuff and it gives everything a nice glossy finish to brighten things up a bit.
The other trick is to remove the under hood light and only open the hood at night in public parking lots. Those giant pole lights give plenty of light to work without showing any dirt. | |
UberWagon
| Subject: Re: ENGINE BAY CLEANING!!!!! Tue Mar 31, 2009 4:54 pm | |
| I simply removed my engine and transmisson, pressure washed the engine, transmission and engine bay, then replaced all the gaskets and seals, then painted stuff my choice of colors, then put the engine back in. What could be easier? | |
| Subject: Re: ENGINE BAY CLEANING!!!!! Tue Mar 31, 2009 5:08 pm | |
| - UberWagon wrote:
- I simply removed my engine and transmisson, pressure washed the engine, transmission and engine bay, then replaced all the gaskets and seals, then painted stuff my choice of colors, then put the engine back in. What could be easier?
dont laugh i knew a guy who did that....many times ... my 65 chevelle i had all white under the hood f/wall . hood. fenders, did alot of nite drag racing ,back in the day , was easier to work on in little light at nite etc, plus there was nothing there anyway, was bare bones just the motor and cool can, battery was in the trunk things were much simpler back then | |
UberWagon
| Subject: Re: ENGINE BAY CLEANING!!!!! Wed Apr 01, 2009 4:04 am | |
| I wasn't kidding. That is what I did right before I shipped my wagon to Germany. I know that is a little extreme for just cleaning the engine bay but I also had numerous oil leaks that had to be repaired prior to the car being shipped and it was easier to just pull the engine and transmission. Here was the end result, and after 4 years it still looks very good, dupli-color engine paint works great. In the past I have had good luck with Gunk engine brite, Simple Green, Tough Stuff and there was some purple stuff the we sold at the parts store I used to work at that worked great too, just don't use high pressure water. I have had issues with that in the past, my mom's 1977 Mercedes 450SEL didn't take kindly to the use of high pressure. I borrowed the car, checked the oil and it was low so I topped it off and left the cap sitting on the intake making a huge mess under the hood. I take it to the car wash, put some quarters in the machine and proceed to clean up my mess, I finished up and I was proud of how clean it was. I get in the car and go to start it and it just turns over, I had to walk back home to tell my Dad the car was dead. We towed it home and even after opening all of the electrical connections and distributor then spraying them with WD-40 the car still didn't start. It took 3 days for the engine to dry out on it's own. I have heard of people using aluminum foil to keep water out of electrical connections and sensitive components but I have never tried it myself so I don't know how well it works. | |
| Subject: Re: ENGINE BAY CLEANING!!!!! Wed Apr 01, 2009 6:55 am | |
| It looks awsome Ray I did the same thing.......... Twice. |
| Subject: Re: ENGINE BAY CLEANING!!!!! Wed Apr 01, 2009 9:23 am | |
| Advance auto is having buy 1 get 1 on techron 2 for $8 Black magic (all types) 2 for $9 amorall (all types) 2 for $5 gunk, gumout,prestone injector cleaner 2 for $8 Jig-A-Loo non-stink lube 2 for $3 gojo 2 for $6 valvoline brake fluid 2 for $6 Brakleen some other specialty stuff I eat this stuff so just giving heads up disclaimer......not a vendor | |
| Subject: Re: ENGINE BAY CLEANING!!!!! Wed Apr 01, 2009 10:17 am | |
| Thanks for the heads up I will probably grab some Black Magic and Gojo. | |
| Subject: Re: ENGINE BAY CLEANING!!!!! Wed Apr 01, 2009 7:11 pm | |
| $15 for S100 at a motorcycle dealer. ALL YOU NEED!!!! It's a cleaner/degreaser than leaves a nice satin finish on everything. Safe for paint. It's THE BALLS!!!! | |
QwikImpSS
Posts : 164 Join date : 2009-02-16 Age : 40 Location : Pembroke, NH
| Subject: Re: ENGINE BAY CLEANING!!!!! Sat Apr 04, 2009 7:54 pm | |
| I did this once by accident on my first car, a 1987 Caprice Classic handed down to me by my parents. I lit the engine bay on fire!!! It was going for 20-30 ticks before I hosed it down.......not a speck of oil in there after that!!!! | |
| Subject: Re: ENGINE BAY CLEANING!!!!! | |
