| | Found this in the 9C1 | |
+5mega 96slowss Cadet57 Matt Trakker MASShole9C1 9 posters | Author | Message |
| | | | Matt Trakker
| Subject: Re: Found this in the 9C1 Fri Mar 04, 2011 5:21 pm | |
| Heh, looks like they took an early 70s Dodge Polara and added some lines from a Ford Galaxie to make it more generic. | |
| | | MASShole9C1
| Subject: Re: Found this in the 9C1 Fri Mar 04, 2011 5:22 pm | |
| lol.thats what Im saying | |
| | | Cadet57
| Subject: Re: Found this in the 9C1 Fri Mar 04, 2011 5:49 pm | |
| That is cool. All I ever found in the wagon was a Christmas shopping list from 1999 and an eyeliner pencil | |
| | | 96slowss
| Subject: Re: Found this in the 9C1 Fri Mar 04, 2011 7:36 pm | |
| i found some tic tacs and a snickers when i got the ss | |
| | | mega
| Subject: Re: Found this in the 9C1 Fri Mar 04, 2011 8:07 pm | |
| | | 95brmw
| Subject: Re: Found this in the 9C1 Fri Mar 04, 2011 9:28 pm | |
| I found about $10 worth of change UNDER the carpet in my 9C1 Also found a 1/2" wrench in the rear quarter panel and a 1/4" drive extension under all the crap on the cowel. | |
| | | Ironfistdog
| Subject: Re: Found this in the 9C1 Fri Mar 04, 2011 10:54 pm | |
| When we got the black 93 I told my wife we should pull up the back seat and take a look, I said "maybe we'll find a 20" and sure enough there was a 20 dollar monopoly bill under the seat. damn you milton bradley!!! On another note my buddy was at a yard in boston looking for RM door panels and he opened a center console and found $100 REAL money! Ever since then I check every car with a console | |
| | | mega
| Subject: Re: Found this in the 9C1 Sat Mar 05, 2011 6:30 am | |
| i love the yard you can find alot there i find change all the time but a 100 damn | |
| | | MASShole9C1
| Subject: Re: Found this in the 9C1 Sat Mar 05, 2011 9:26 am | |
| If it IS there, where would I be able to look for my build sheet? The back seat isnt original, and its not under there. Ive had the entire interior of my '96 out several times | |
| | | mega
| Subject: Re: Found this in the 9C1 Sat Mar 05, 2011 9:29 am | |
| i found a piece of my build sheet under my trunk carpet but you can do a vincheck on it and will give you everything. | |
| | | mega
| Subject: Re: Found this in the 9C1 Sat Mar 05, 2011 9:36 am | |
| go here might help ya out http://www.compnine.com/vid.php?vin=1g1bl52w0rr125693
i found this bout mine
Found 96,919 vehicles matching your year and model in our database. RPO Description Matches UM6 RADIO,AM/FM STEREO,CASSETTE,ETR,INCLUDES CLOCK STEREO CASSETTE(UM6) 57,893 UQ1 RADIO,PROVISIONS FOR STEREO STEREO RDO PR0VISIONS(UQ1) 91,365 UQ5 SPEAKER SYSTEM,4,DUAL FRONT DOOR MOUNTED,DUAL EXTENDED RANGE QUARTER MOUNTED 4 SPKR SYS(UQ5) 64,594 U02 CLUSTER,INSTRUMENT,KILOMETER AND MILES,DIGITAL DISPLAY DIGITAL DISPLAY CSTR(U02) 65,157 U73 ANTENNA,FIXED FIXED ANT(U73) 60,045 VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3) 82,526 V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73) 86,007 1AY ORDER MODIFICATION - STOCK 32,029 1SD PACKAGE-OPTION 04 (1SD) 14,440 6TF COMPONENT-COMPUTER SELECTED SUSPENSION SUSP(6TF) 19,616 7TH COMPONET-COMPUTER SELECTED SUSPENSION SUSP(7TH) 19,616 77Q MOLDING COLOR,DARK MAPLE RED METALLIC (77Q) 4,577 77U EXTERIOR COLOR,PRIMARY (77U) EXTERIOR COLOR,PRIMARY,DARK CHERRY METALLIC (77U) 4,839 79B TRIM COMBINATION CLOTH, RUBY RED (B) (93) (79B) 8,956 79I INTERIOR TRIM,RUBY RED (79I) 15,575 8RZ COMPONENT RR LH - COMPUTER SEL SUSP (8RZ) SUSP(8RZ) 27,795 9RZ COMPONENT RR RH - COMPUTER SEL SUSP (9RZ) SUSP(9RZ) 19,118 AA7 WINDOW,ELECTRIC OPERATED,QUICK OPENING QUICK OPG ELEC WDO(AA7) 88,588 AK5 RESTRAINT SYSTEM,FRONT SEAT,INFLATABLE,DRIVER AND PASSENGER DRIVER & PASS F/SEAT INFL RST SYS(AK5) 96,919 AM6 SEAT,FRONT SPLIT,3 PASSENGER WITH CENTER ARMREST FRT SPLIT ST(AM6) 59,226 ARL PLANT CODE-ARLINGTON TX, CPC ARLINGTON,TX ASSEMBLY PLANT(ARL) 96,919 AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3) 93,498 A90 LOCK,REAR COMPARTMENT LID,REMOTE CONTROL,ELECTRIC RELEASE ELEC REL LID LK(A90) 61,609 C49 DEFOGGER,REAR WINDOW,ELECTRIC ELEC RR WDO DEFG(C49) 88,804 C60 AIR CONDITIONER,FRONT,MANUAL CONTROLS A/C MAN CONT(C60) 96,919 DG7 MIRROR,OUTSIDE,RH & LH REMOTE CONTROL,ELECTRIC(PAINTED) O/S ELEC R/CON PAINTED MIR(DG7) 53,559 FE1 SUSPENSION SYSTEM,SOFT RIDE SOFT RIDE SUSP(FE1) 27,795 FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9) 77,693 GU2 AXLE,REAR,2.73 RATIO 2.73R(GU2) 39,578 IQB TRIM,INTERIOR DESIGN (IQB) 29,307 JA1 BRAKE SYSTEM,LIGHT WEIGHT,DISC,DRUM LGT WT BRK SYS(JA1) 38,851 JM4 BRAKE SYSTEM,POWER FRONT DISC,REAR DRUM,ANTI-LOCK(CAST IRON) ANTILOCK DISC/DRUM BRK(JM4) 58,854 K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34) 67,410 K68 GENERATOR,105 AMPERE 105 AMP(K68) 36,879 L99 ENGINE GAS, 8 CYL, 4.3L, MFI 4.3W(L99) 52,793 MX0 TRANSMISSION,AUTOMATIC,OVERDRIVE(MERCHANDISING OPTION) A/TRANS PROVISIONS(MX0) 96,919 M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30) 96,919 NA5 EMISSION SYSTEM,FEDERAL REQUIREMENTS FEDERAL EMIS(NA5) 88,713 N30 STEERING WHEEL(DELUXE) DELUXE STRG WHL(N30) STEERING WHEEL(DELUXE)(EXPORT) DELUXE STRG WHL(N30)(EXPORT) 77,215 N40 STEERING,HYDRAULIC(NON-VARIABLE) NON-VARIABLE P/S(N40) 96,919 N81 TIRE,SPARE(FULL SIZE RADIAL) FULL SIZE RADIAL SPA(N81) TIRE,SPARE(FULL SIZE RADIAL)(EXPORT) FULL SIZE RADIAL SPA(N81)(EXPORT) 73,528 PB1 COVER,WHEEL,15 INCH 15 INCH WHL CVR(PB1) 25,203 PH1 WHEEL,15X7(STEEL) STEEL WHL(PH1) 32,989 QCV TIRE ALL P215/75R15/N WS2 R/PE ST TL ALS TIRE(QCV) 25,920 R6A CONTROL - SALES ITEM NO. 01 18,927 R7A CONTROL - SALES ITEM NO. 26 80,916 R7R CONTROL - SALES ITEM NO. 42 30,356 R8T CONTROL - SALES ITEM NO. 69 18,870 Rarity...
There are 47 1994 CAPRICE CLASSIC 4 DR vehicles (0.048%) matching your exact options list. There are 64 (0.066%) with at least as many options.
My car is really common, why does this indicate that it's rare? If you parked your car next to one of the hundreds or thousands of similar cars in our database you probably couldn't tell them apart, but that doesn't mean they aren't different.
For example, some may have an RPO listing for the plant in which they were built. If yours was one of only a few that came out of that plant with a given list of options, it would come back as rare. Another car may have all the same options but was built at a different facility and thusly it's considered different.
To check any combination of RPO codes to find how rare your vehicle is based on the most important codes, click here.
| | | Matt Trakker
| Subject: Re: Found this in the 9C1 Sat Mar 05, 2011 9:54 am | |
| I'm pretty sure nothing in my car has ever been touched, so I'm hoping to find the build sheet just for the hell of it, would be kinda cool.
When I got my Caprice I found a 40+ year old first aid kit in the glove compartment, index cards to held remind the previous owner (old lady) what the switches on the dash did, a billion ice scrapers, green carpet samples, a set of car keys with the knockouts still in them down in the quarter panel (caused a rot hole from electrolysis), change tray full of pennies, forget what else | |
| | | mega
| Subject: Re: Found this in the 9C1 Sat Mar 05, 2011 9:56 am | |
| i like how that page says there were 47 built like mine pretty cool now if i can get the production number of mine be nice to have at shows. | |
| | | mega
| Subject: Re: Found this in the 9C1 Sat Mar 05, 2011 10:00 am | |
| Year Units 1991 217,462 1992 116,781 1993 100,648 1994 104,048 1995 80,737 1996 69,581 Total production 689,257 i found how many caprices and impalas were built from 91 to 96 i wonder how many 94's were 4.3l
| | | GasTT
| Subject: Re: Found this in the 9C1 Sat Mar 05, 2011 12:10 pm | |
| You answered your own question. - mega wrote:
- L99 ENGINE GAS, 8 CYL, 4.3L, MFI 4.3W(L99)
52,793
| | | mega
| Subject: Re: Found this in the 9C1 Sat Mar 05, 2011 12:31 pm | |
| i know i did lol saw it after i posted lmao now to find out what my prodution number is pretty cool on how theres only less tham 5000 DCMs made in 94 | |
| | | onehunglo
| Subject: Re: Found this in the 9C1 Sat Mar 05, 2011 2:06 pm | |
| - MASShole9C1 wrote:
- If it IS there, where would I be able to look for my build sheet? The back seat isnt original, and its not under there. Ive had the entire interior of my '96 out several times
I found my build sheet under my pass seat! | |
| | | MASShole9C1
| Subject: Re: Found this in the 9C1 Sat Mar 05, 2011 2:26 pm | |
| My 9C1 is 1 of 15 out of the 90 something thousand made that year | |
| | | Cadet57
| Subject: Re: Found this in the 9C1 Sat Mar 05, 2011 2:47 pm | |
- My 9C1 is 1 of 15 out of the 90 something thousand made that year
Interesting that there are only 15 like your 9C1 when the LAPD (or is it sheriff dept) must have ordered way more than 15 that year. | |
| | | mega
| Subject: Re: Found this in the 9C1 Sat Mar 05, 2011 3:04 pm | |
Interesting that there are only 15 like your 9C1 when the LAPD (or is it sheriff dept) must have ordered way more than 15 that year. that is interesting you know what is really interesting a detective here on cape used my car for a few years as his cruser and its not a 9c1 hmmmm. | |
| | | Cadet57
| Subject: Re: Found this in the 9C1 Sat Mar 05, 2011 3:05 pm | |
Interesting that there are only 15 like your 9C1 when the LAPD (or is it sheriff dept) must have ordered way more than 15 that year. that is interesting you know what is really interesting a detective here on cape used my car for a few years as his cruser and its not a 9c1 hmmmm. Its pretty common actually. Chicopee does that too. Some of the detective crown vics aren't P71's. Just base Vics with strobes and a radio added. The chief has a plain Five Hundred/ Taurus with the same setup. | |
| | | MASShole9C1
| Subject: Re: Found this in the 9C1 Sat Mar 05, 2011 3:09 pm | |
| I thought that too. It was a cruiser assigned to the L.A. County Sheriffs office Reserve Unit. Who knows how many they had ordered. I have the records from George Bates Caprice and Impala Refurbishers. Very helpfull in obtaining everything. They had to dig, but sent all original documents to include the GM invoice for the new LT1 and trans. | |
| Subject: Re: Found this in the 9C1 | |
