| My new ride | |
+10Grumpy V8Killer toomanytoyz MASShole9C1 1984twodoor 95brmw Cadet57 IMPALADAKID No Moa sdstick 14 posters |
| Subject: My new ride Wed Jan 05, 2011 10:18 am | |
| Subject: Re: My new ride Wed Jan 05, 2011 10:23 am | |
| Nice!!! Just remember...its not the wagon so dont turn into a corner early Is that the FASTEST color? Tough to tell in thos pics. | |
| Subject: Re: My new ride Wed Jan 05, 2011 10:24 am | |
IMPALADAKID Admin
| Subject: Re: My new ride Wed Jan 05, 2011 10:34 am | |
| - No Moa wrote:
- I dont' want to start a war (again) but did you trade the wagon in?
Nice car. No war. I sold the wagon, and then purchased the Regal. | |
| Subject: Re: My new ride Wed Jan 05, 2011 10:39 am | |
| Good to hear, good luck with the regal. | |
| Subject: Re: My new ride Wed Jan 05, 2011 10:49 am | |
| Sweet ride. Wait... the wagon is...gone? | |
| Subject: Re: My new ride Wed Jan 05, 2011 12:55 pm | |
| Nice looking car, bet it moves a bit better than my riv with how much less it weighs. Watch those lower intake manifold gaskets! They claimed my Riv's original engine. | |
| Subject: Re: My new ride Wed Jan 05, 2011 1:29 pm | |
- Now that the wagon is gone, I needed something more practical, and newer, so I came across this:
1999 Regal GSE Supercharged. 157k, and loaded with every option. Billy likey
Fitting plate for a sedan Looks good though. Whats the power numbers for the supercharged six? | |
| Subject: Re: My new ride Wed Jan 05, 2011 1:36 pm | |
| - 1984twodoor wrote:
- Fitting plate for a sedan
Looks good though. Whats the power numbers for the supercharged six?[/quote] LOL. It was a lot cheaper to transfer the plates. Cost me 49 bucks total for the transfer. Numbers are 240hp/280ft lbs of torque. The wagon could take it off the line all day long, but it has it beat every where else.
| Subject: Re: My new ride Wed Jan 05, 2011 3:36 pm | |
| Whats the fuel economy look like for that buick? Im toying with the idea of dropping the gold Caprice and moving on to a more practical commute. | |
| Subject: Re: My new ride Wed Jan 05, 2011 3:57 pm | |
| Sweet Century! We need a W body section or something now... I've been thinking about one too, to play with. Monte, Bonnie, Regal, GTP, Riv, Impy???? Who knows... Good luck with it. I diggit! | |
| Subject: Re: My new ride Wed Jan 05, 2011 5:04 pm | |
- Sweet Century!
It's a REGAL! Not a Century! - toomanytoyz wrote:
- Good luck with it. I diggit!
Thanks man! |
Grumpy
| Subject: Re: My new ride Wed Jan 05, 2011 5:33 pm | |
| mileage 25 ish .. Unless ya drive it like ya stole it.. Then about 18/20 | |
| Subject: Re: My new ride Wed Jan 05, 2011 5:57 pm | |
| - 95brmw wrote:
- ...... Watch those lower intake manifold gaskets! ......
Done them a couple of times, not a bad job (not counting the time spent praying the manifold seals) Do they still put the belt around the motor mount? | |
| Subject: Re: My new ride Wed Jan 05, 2011 6:18 pm | |
| Didn't know they made them SC'ed, nice! | |
| Subject: Re: My new ride Wed Jan 05, 2011 7:53 pm | |
| If you were going to get a W-body, I'm glad you got this exact one. I bet with that mileage, the gaskets have been done already. I like it! | |
| Subject: Re: My new ride Wed Jan 05, 2011 7:56 pm | |
| - Matt Trakker wrote:
- If you were going to get a W-body, I'm glad you got this exact one.
I like it! It looks like it has been done. I now need to put brakes all around. Pads and rotors, and replace the evap vent purge valve, color sand and buff the paint, and she should be ready to start modding. |
Grumpy
| Subject: Re: My new ride Wed Jan 05, 2011 8:05 pm | |
| Daughter has had 2 GTPs as DDs .. A new 04 and a 07. 04 had a little over a 100k .. Gaskets went when the car only had 20k or so.. Under warrenty.. 07 has a little over 150k.. Brakes, tires, and oil changes.. That is it.. Like I said they are/were driven hard !! Nice dependable cars !! | |
| Subject: Re: My new ride Thu Jan 06, 2011 11:30 am | |
| Subject: Re: My new ride Thu Jan 06, 2011 11:38 am | |
| Can the GSC come off the back? DRGNWGN may make them wonder , but assuming the SC is supercharged THAT will alert them for sure Nice bum BTW | |
JaySS
| Subject: Re: My new ride Thu Jan 06, 2011 12:57 pm | |
- I now need to put brakes all around. Pads and rotors, and replace the evap vent purge valve, color sand and buff the paint, and she should be ready to start modding.
If the car needs brakes, look around before you spring for replacement rotors - the later models had both larger diameter rotors, and some had both larger and wider rotors that can be retrofitted. Some only need to use a different caliper bracket, which are cheap. Wider will need the corresponding calipers, but those can be had for short money too, not that you work near an auto parts store or something. Most of the upgrades offered below just alternate GM parts they are packaging as a kit. http://www.thrashercharged.com/tech_htm/brakes.shtm http://www.wbodystore.com/grandprix/Brakes-c-8.html http://www.zzperformance.com/grand_prix/products.php?id=138 LS1 F-body stuff can be retrofitted too - just get the parts away from Jim before he realizes what you're up to. http://www.clubgp.com/newforum/tm.asp?m=2434239&p=7&tmode=1&smode=1&cookieCheck=671734297 - J | |
| Subject: Re: My new ride Thu Jan 06, 2011 4:25 pm | |
| Subject: Re: My new ride Thu Jan 06, 2011 9:23 pm | |
| nice ride i can see the dirt from here ..... we got that same colored option car on the used car lot right now....... want a spare?
| Subject: Re: My new ride Fri Jan 07, 2011 10:07 am | |
| Doh! Linkfail!!!!!!! Maybe this one'll work.... Or this one? And I lol'd at "liverlips"! How old are you, anyways??? Buying a century and making jokes like that? | |
| Subject: Re: My new ride Fri Jan 07, 2011 10:26 am | |
| Subject: Re: My new ride Fri Jan 07, 2011 12:15 pm | |
| Subject: Re: My new ride Mon Jan 31, 2011 1:31 am | |
| After seeing these things in action at the dragstrip on youtube, I really think I will consider one for a future DD. I had no idea they were that quick! There are people that dump thousands into Mustangs and wind up with a car that runs the same times... | |
| Subject: Re: My new ride Tue Feb 01, 2011 9:35 am | |
- After seeing these things in action at the dragstrip on youtube, I really think I will consider one for a future DD. I had no idea they were that quick! There are people that dump thousands into Mustangs and wind up with a car that runs the same times...
My understanding is. 5 simple mods: Headers, Tune, 3.4" pulley, CAI and delete the u-bend in the Exhaust, and you are in the mid 13 second range. I guess stock is mid to high 14s. |
| Subject: Re: My new ride Tue Feb 01, 2011 8:38 pm | |
| Subject: Re: My new ride | |
| My new ride | |
