| Good Morning! | |
| Subject: Good Morning! Sat Nov 20, 2010 9:59 am | |
| Well, I hope you guys have a better morning than me so far! 645am meeting at my work(off the clock, because of my ankle..). Left there at 730, headed to dunks, and uhh.. | |
| Subject: Re: Good Morning! Sat Nov 20, 2010 10:14 am | |
| I find it funny this happens 24 hours after you said I should buy a cheap b-body and sell the VW But seriously, that sucks dude. I hope its a cheap an easy fix. *edit* saw that you have the parts. Thats good. Btw, you still have that parts car? I may be interested in the rear seat assembly..oh and the quarters | |
| Subject: Re: Good Morning! Sat Nov 20, 2010 10:37 am | |
| Parts car is going next weekend, seriously lol. Ive said that a couple times, but its GOT to go.. Parts are there if you want them.. | |
| Subject: Re: Good Morning! Sat Nov 20, 2010 10:39 am | |
| - 96Brougham wrote:
- Parts car is going next weekend, seriously lol. Ive said that a couple times, but its GOT to go.. Parts are there if you want them..
You doing anything holiday related next friday? I have the day off, probably my last one til xmas. | |
| Subject: Re: Good Morning! Sat Nov 20, 2010 10:41 am | |
| that sucks. does the parts car u have have a good heater core? mine started 2 leak | |
| Subject: Re: Good Morning! Sat Nov 20, 2010 10:45 am | |
| - 96slowss wrote:
- that sucks. does the parts car u have have a good heater core? mine started 2 leak
I'd assume so, cars only got 65k on it.. Heat worked when I drove it home after buying it.. | |
| Subject: Re: Good Morning! Sat Nov 20, 2010 10:47 am | |
| Subject: Re: Good Morning! Sat Nov 20, 2010 11:15 am | |
The blue or the gold parts car? | |
| Subject: Re: Good Morning! Sat Nov 20, 2010 12:14 pm | |
I dont have a blue or gold parts car, ive just got the white woody with tan guts.. | |
| Subject: Re: Good Morning! Sat Nov 20, 2010 12:16 pm | |
| - 96slowss wrote:
- how much u want for it?
come take it out and its yours | |
| Subject: Re: Good Morning! Sat Nov 20, 2010 12:52 pm | |
| Sorry, I meant the white one, or the blue one (de-wooded) one? I figured any more stuff goes wrong and you'll be parting out the blue one. | |
| Subject: Re: Good Morning! Sat Nov 20, 2010 5:38 pm | |
| A brass barbed garden hose repair fitting works well there, too. | |
| Subject: Re: Good Morning! Sun Nov 21, 2010 2:33 pm | |
| I just received two new ones from hamilton chevrolet as there are still a few left in the system. Before I realized that though, I used up two salvaged ones (with the green hoses) from my "parts 9C1s" & they BOTH FAILED. It is plastic & connects 5/8" to 3/4" straight through but has a 3/4" "tee" at 90 degrees. They get to this age and they are brittle. I would never trust them on my heater core outlet hose. I made up a new connector-TEE from brass barbed fittings from the "help" section at the auto parts store & got a 1/2" female pipe threaded three way tee (also in brass) from the plumbing supply. If you want a new one, try . . . http://cgi.ebay.com/ebaymotors/Heater-Hose-T-Fitting-Impala-SS-LT1-Caprice-9C1-Buick-_W0QQcmdZViewItemQQhashZitem563fb3b481QQitemZ370435929217QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_619wt_941 . . . Mike, who handles the ebay dept there, is truly an excellent & knowledgable source, PLUS he owns several 9C1s. The original ones had the bent hose that goes up to the bottom of the expansion tank permanently attached with a tubular aluminum piece swaged over to grip the hose. I simply cut that aluminum piece off carefully & used conventional SS hose clamps to re-attach the 3/4"hose. No more leaks now. { $13.99 BTW for the correct original GM part! } I DO see that your heater INLET hose was the one that failed, but not ANY of my bubble 9C1s had that black plastic "fitting" at its end. On my cars, the heater core inlet hose goes straight onto a pipe on both ends. What is purpose of that devise? I imagine that it may be a "one direction check valve" | |
| Subject: Re: Good Morning! | |
| Good Morning! | |
