Got a few things done today EmptyWed Oct 19, 2022 1:27 pm by scot
Got a few things done today EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Got a few things done today EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Got a few things done today EmptyFri Sep 24, 2021 9:53 am by ElKy
Got a few things done today EmptySun Sep 19, 2021 6:22 pm by black blur 96
Got a few things done today EmptySun Jun 20, 2021 11:37 am by scot
Got a few things done today EmptyFri Jun 11, 2021 10:41 am by scot
Got a few things done today EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Got a few things done today EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
8 posters
PostSubject: Got a few things done today   Got a few things done today EmptySat Sep 11, 2010 4:13 pm
I removed the betal passenger seat relocators to put the seat in it's correct position. There was two spacers placed to the back. I assume to make the passenger seat level for the police to place things on it. I put them to the front to put more angle on the seat for comfort reasons.
Then I pulled the speedometer display out and performed this fix http://capricess.com/tech/cluster/fading_cluster/fix.htm
, adjusted the slop out of the steering box. Now it feels great. Just need an alignment. cheers , and finally, I removed the rumble seat, and seat belts in the far back to make room for storage.
All four mods/fixes took just a couple hours and cost me nothing but time. afro
PostSubject: Re: Got a few things done today   Got a few things done today EmptySat Sep 11, 2010 4:16 pm
Good job. I love the wagon(and spare time to fix and mod Smile ) Your wagon makes me consider my next money pit to be one! Lots of plans on the drawing board and such geek
PostSubject: Re: Got a few things done today   Got a few things done today EmptySat Sep 11, 2010 4:36 pm
I have superimposing #'s in my digital display in the B4U, I'm guessing that this will do the job.
PostSubject: Re: Got a few things done today   Got a few things done today EmptySat Sep 11, 2010 5:00 pm
It worked for me perfectly. I had superimposed numbers, and fading bad. The other day, I could not see it during the day. Now it works like new. I took it a step further and took an emory board and lightly sanded the contact points smooth, and used q-tips and alcohol to clean the contact points.
PostSubject: Re: Got a few things done today   Got a few things done today EmptySat Sep 25, 2010 9:58 pm
Got a few more things done today. Replaced the oil cooler lines, and gutted the cats. Anyone know how to hook the SCV on the radio so it works.
PostSubject: Re: Got a few things done today   Got a few things done today EmptySat Sep 25, 2010 10:33 pm
From what I understand the scv has it's own dedicated wire coming out of the stereo and it ties directly into the vss signal. I may be off though because on some cars I hear it ties into the signal between the pcm and the speedo.
If you can find the scv wire you can try either source and see which one works correctly. Otherwise wait for someone with the fsm to check their diagrams.
PostSubject: Re: Got a few things done today   Got a few things done today EmptySat Sep 25, 2010 10:38 pm
Based on the Lenco diagram for the 94-96 Roadmaster there's a "VF-PWM" wire at E4 that's purple/white and ties into the A/C system. Maybe that's it scratch
The '93 diagram shows the same thing but at C4.
I'd guess that's what you're looking for
PostSubject: Re: Got a few things done today   Got a few things done today EmptySat Sep 25, 2010 10:44 pm
Scratch that.
From Hack
Speed Compensated Volume - DARK GREEN/WHITE Wire - Pin 16
Got a few things done today Radio_10
PostSubject: Re: Got a few things done today   Got a few things done today EmptySat Sep 25, 2010 10:51 pm
Scratch that.
From Hack
I assume that is the plug that goes to the back of the radio. But where does the wire go from there? The VSS?, The PCM?, someplace under the dash?
PostSubject: Re: Got a few things done today   Got a few things done today EmptySat Sep 25, 2010 10:57 pm
Most of the times it's disconnected just from getting the wire cut. I'd try to follow the wire from the stock harness and where it ends you'll probably find the other end of the wire just hanging near by. It's not the most technically grand answer, but it's what I would do first. Never like tapping into random wires on a car that has this many electrical signals. If you find the wire has been removed completely then I'm sure someone can pull out an fsm and trace the wire coming from the stereo at pin 16.
PostSubject: Re: Got a few things done today   Got a few things done today EmptySat Sep 25, 2010 11:00 pm
I am not sure the 95 b-bodys ever had the option, so I am almost 100% sure there is no wire for it. There may be a slot on the connector, but no wire.
PostSubject: Re: Got a few things done today   Got a few things done today EmptySun Sep 26, 2010 1:38 pm
I'm pretty sure the 95's had that option. I know my 95 had a few extra wires in the stereo harness that I didn't use when I put in the aftermarket stereo. Never had the stock stereo so I don't know if it was hooked up or not.
PostSubject: Re: Got a few things done today   Got a few things done today EmptySun Sep 26, 2010 2:32 pm
How's it sound with gutted cats? Give it a weird tone?
PostSubject: Re: Got a few things done today   Got a few things done today EmptySun Sep 26, 2010 2:50 pm
Yes!
PostSubject: Re: Got a few things done today   Got a few things done today EmptySun Sep 26, 2010 3:06 pm
Woah. No need to be so descriptive... Wink
PostSubject: Re: Got a few things done today   Got a few things done today EmptySun Sep 26, 2010 3:39 pm
connector C200 cavity D8 drk grn/wht crk 817 VSS
PostSubject: Re: Got a few things done today   Got a few things done today EmptySun Sep 26, 2010 4:25 pm
Sorry
I was on my phone, and it is hard to respond. I will answer later when I can get to my pc
PostSubject: Re: Got a few things done today   Got a few things done today EmptySun Sep 26, 2010 7:08 pm
Ok, now that I am home.
The tone is now hollow, and tingy. Also there is more noise in the cabin than before the gutting.
I am not happy with the sound at all, but I was sure I had a broke up cat, so I gutted it to make the noise go away. Problem is the noise is still there. Sounds like a marble in a metal can bouncing around when I first take off under moderate to full throttle, then goes away. It really gets bad if I go around a corner. I think the cats were both a bit clogged, but intact on the Exhaust side, and I was sure the drivers cat had a piece broke off in the manifold side. I am at a loss as to where the mystery noise comes from. I can't duplicate it standing still. I have tried to make it happen as I approch a wall, so I can get an idea of front or back, yet it sounds the same either way. Had one person stand outside the car as I took off and they could not tell either. Really beginning to piss me off. Like a Star @ heaven
PostSubject: Re: Got a few things done today   Got a few things done today EmptySun Sep 26, 2010 7:28 pm
Hmm.. my stepfathers car had a noise, a piece of the starter broke off and under half to full throttle would get kicked up and spun by the flywheel.. byt that was more of an "omg wtf just broke inside my engine" kind of noise..
PostSubject: Re: Got a few things done today   Got a few things done today EmptySun Sep 26, 2010 7:37 pm
Try hitting the mufflers. Something rattling in there?
Acorns in the framerails or roof racks? Don't laugh, it's happened before. Wink
PostSubject: Re: Got a few things done today   Got a few things done today EmptySun Sep 26, 2010 7:46 pm
My next area to look at.
Not there. I had the roof rack off and tried to install those fillers, and cleaned everything up.
PostSubject: Re: Got a few things done today   Got a few things done today EmptySun Sep 26, 2010 7:53 pm
Bill M., take a deep breath. Now step away from the FOR SALE sign.
Tom C.
PostSubject: Re: Got a few things done today   Got a few things done today EmptySun Sep 26, 2010 7:57 pm
Tom C.
I threw that old thing away.
Just want to find the culprit. I have already wasted a good pair of cats trying to find it.
PostSubject: Re: Got a few things done today   Got a few things done today EmptySun Sep 26, 2010 10:33 pm
On the 3rd take me for a spin around the block. I'm good at distinguishing sound direction. Something about being able to tell if a sound is coming from my right or left ear and then shifting my head to pinpoint. Like a radar tower Laughing
PostSubject: Re: Got a few things done today   Got a few things done today EmptyMon Sep 27, 2010 5:54 am
Cool! I can duct tape you to the driveshaft, and you can listen for the sound. Razz jocolor geek
PostSubject: Re: Got a few things done today   Got a few things done today EmptyMon Sep 27, 2010 7:02 pm
Might be tricky to pinpoint with all the spinning Razz
PostSubject: Re: Got a few things done today   Got a few things done today EmptyMon Sep 27, 2010 8:25 pm
In this case the noise is coming from Brads mouth
PostSubject: Re: Got a few things done today   Got a few things done today EmptyMon Sep 27, 2010 8:26 pm
LOL! Laughing Razz Very Happy jocolor geek
And poor brad has not said a word. scratch
» few things f/s
» Things may be looking up!
» I Wanna Do Bad Things With You
» Things to do when you have nothing to do.......... PAINT MAYBE!!!!
» Few Things For Sale
