| Dropped the nose a bit | |
+5MASShole9C1 96slowss Pooge bfurches toomanytoyz 9 posters |
| Subject: Dropped the nose a bit Wed Aug 18, 2010 5:05 pm | |
| After seeing Als car lowered, I decided to get off my ass, and set mine up with the rake I wanted. I took the stock uncut set of 9C1 springs that Mark Ross had given me, and cut one coil+2" out of it, then sanded and painted them before install. I will get an alignment tomorrow, and be good to go until I can get another steering box with less play. Before: After: |
| Subject: Re: Dropped the nose a bit Wed Aug 18, 2010 5:22 pm | |
| That looks much better! (but cut another 1/2 coil!) | |
| Subject: Re: Dropped the nose a bit Wed Aug 18, 2010 5:44 pm | |
| that does look pretty nice.
How does it ride with the cut springs? | |
| Subject: Re: Dropped the nose a bit Wed Aug 18, 2010 5:57 pm | |
| - bfurches wrote:
- that does look pretty nice.
How does it ride with the cut springs? I rides the same same as stock. |
| Subject: Re: Dropped the nose a bit Wed Aug 18, 2010 6:22 pm | |
| Look great man, I really like it! | |
| Subject: Re: Dropped the nose a bit Wed Aug 18, 2010 8:33 pm | |
| looks good but... it would look better like this.. Uploaded with ImageShack.us | |
| Subject: Re: Dropped the nose a bit Wed Aug 18, 2010 9:56 pm | |
| Looks awesome! I'd go lower, but who am i to talk. I have one half lowered and the srings for the other buried in the basement | |
| Subject: Re: Dropped the nose a bit Wed Aug 18, 2010 10:51 pm | |
| I might go lower. After seeing the photoshop of it, I feel I did not go far enough. That pic ruined my glory. |
| Subject: Re: Dropped the nose a bit Thu Aug 19, 2010 7:07 am | |
| i figured u would like that | |
| Subject: Re: Dropped the nose a bit Thu Aug 19, 2010 7:37 am | |
| Much better, but i'd go lower too Give it a bit, might settle a little more. | |
| Subject: Re: Dropped the nose a bit Thu Aug 19, 2010 12:47 pm | |
- I might go lower. After seeing the photoshop of it, I feel I did not go far enough. That pic ruined my glory.
Well if that's true I certainly wouldn't park next to Anthony on Sunday. | |
booth9C1SS
| Subject: Re: Dropped the nose a bit Tue Aug 31, 2010 9:00 pm | |
| The front wagon springs are the same as the impala SS springs, so if you only cut 2" of a coil, you are probably still taller than stock. I have 9C1 springs with one full coil cut off and love it. Stock wheels are even with the top of the fender lip... yet I still have room for 235/75R15 snow tires in the winter!
If I were to do it again, though, I would only cut off 3/4 coil. | |
| Subject: Re: Dropped the nose a bit Tue Aug 31, 2010 10:40 pm | |
| The car has settled now, and the tire is even with the lip. It looks awesome. And the frame is resting on the ZQ8 bump stops. |
| Subject: Re: Dropped the nose a bit Tue Aug 31, 2010 10:46 pm | |
| You should probably trim them bumpstops then eh? | |
| Subject: Re: Dropped the nose a bit Tue Aug 31, 2010 10:59 pm | |
| - Fishah wrote:
- You should probably trim them bumpstops then eh?
That is what the rust on the frame is doing. |
| Subject: Re: Dropped the nose a bit | |
