» Anybody out there?
T56 flywheels EmptyWed May 01, 2024 10:41 am by BostonChevy
T56 flywheels EmptyWed Oct 19, 2022 1:27 pm by scot
T56 flywheels EmptyTue Oct 18, 2022 8:58 pm by silverfox103
T56 flywheels EmptyTue Sep 28, 2021 11:01 pm by silverfox103
T56 flywheels EmptyFri Sep 24, 2021 9:53 am by ElKy
T56 flywheels EmptySun Sep 19, 2021 6:22 pm by black blur 96
T56 flywheels EmptySun Jun 20, 2021 11:37 am by scot
T56 flywheels EmptyFri Jun 11, 2021 10:41 am by scot
T56 flywheels EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
May 2024
 T56 flywheels
3 posters
T56 flywheels Empty
PostSubject: T56 flywheels   T56 flywheels EmptyFri May 28, 2010 4:05 pm
Anyone know the differences of the LT1 corvette flywheel versus the camaro/TA flywheel? I have a guy with a vette flywheel, but it looks alot different. So i don't really want to buy it if it won't work.
T56 flywheels Empty
PostSubject: T56 flywheels   T56 flywheels EmptyFri May 28, 2010 4:30 pm
glen i believe larry sr. is running a c4 vette fly wheel in his impy. but i dont know what the difference is. unless its bigger or the weight.
T56 flywheels Empty
PostSubject: Re: T56 flywheels   T56 flywheels EmptyFri May 28, 2010 8:23 pm
The vette flywheel is a "dual mass" flywheel. It's pretty much two metal plates sandwiching a harmonic material between them. They are meant to run with a solid hub clutch disc. I've actually been looking for another one of those... You can use it, but you will need an LT4 specific solid hub clutch disc, too. Also keep in mind that they use different bolts to hold it to the crankshaft.
T56 flywheels ToastedSig_zps6c195980
T56 flywheels Empty
T56 flywheels
