| Subject: T56 flywheels Fri May 28, 2010 4:05 pm | |
| Anyone know the differences of the LT1 corvette flywheel versus the camaro/TA flywheel? I have a guy with a vette flywheel, but it looks alot different. So i don't really want to buy it if it won't work. | |
| Subject: T56 flywheels Fri May 28, 2010 4:30 pm | |
| glen i believe larry sr. is running a c4 vette fly wheel in his impy. but i dont know what the difference is. unless its bigger or the weight. | |
| Subject: Re: T56 flywheels Fri May 28, 2010 8:23 pm | |
| The vette flywheel is a "dual mass" flywheel. It's pretty much two metal plates sandwiching a harmonic material between them. They are meant to run with a solid hub clutch disc. I've actually been looking for another one of those... You can use it, but you will need an LT4 specific solid hub clutch disc, too. Also keep in mind that they use different bolts to hold it to the crankshaft. | |
| Subject: Re: T56 flywheels | |
