If it's going to be street driven, and not raced, then the Autozone clutch setup is fine for you.
And yes. The stock shaft will work. But depending on the gears you put out back, you may or may not run into vibration problems at highway speeds. But you can certainly drive it with the stock unit with no problem.
Thanks Bill, I'm running 373 gear for now, I've got the gears, the reluctor, and i'm getting a rear end from doug to put everything into then into the car. I'll eventually take the original rearend and install 410 gears. Kinda budget for now.
