need some PCM  tuning Suggestions? EmptyWed Oct 19, 2022 1:27 pm by scot
need some PCM  tuning Suggestions? EmptyTue Oct 18, 2022 8:58 pm by silverfox103
need some PCM  tuning Suggestions? EmptyTue Sep 28, 2021 11:01 pm by silverfox103
need some PCM  tuning Suggestions? EmptyFri Sep 24, 2021 9:53 am by ElKy
need some PCM  tuning Suggestions? EmptySun Sep 19, 2021 6:22 pm by black blur 96
need some PCM  tuning Suggestions? EmptySun Jun 20, 2021 11:37 am by scot
need some PCM  tuning Suggestions? EmptyFri Jun 11, 2021 10:41 am by scot
need some PCM  tuning Suggestions? EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
need some PCM  tuning Suggestions? EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
4 posters
LandMaster
LandMaster
PostSubject: need some PCM tuning Suggestions?   need some PCM  tuning Suggestions? EmptyMon Mar 08, 2010 3:08 pm
So I found this insanely clean 96 Roadmaster for cheap ( I mean the paint is still on the frame and rear quarters could be eaten off of.) with like 70k on it. But it's got the CEL on from the AIR pump, if I got the PCM retuned to get rid of the AIR would that take of the CEL light? How much would a retune run me and who should i have it done by as well?
PostSubject: Re: need some PCM tuning Suggestions?   need some PCM  tuning Suggestions? EmptyMon Mar 08, 2010 3:27 pm
yes a tune will fix the CEL you're going to need an OBD2 tune
http://www.impalassforum.com/vBulletin/showthread.php?t=238655&highlight=tuners
PostSubject: Re: need some PCM tuning Suggestions?   need some PCM  tuning Suggestions? EmptyMon Mar 08, 2010 6:40 pm
http://pcmperformance.com/
LandMaster
LandMaster
PostSubject: Re: need some PCM tuning Suggestions?   need some PCM  tuning Suggestions? EmptyMon Mar 08, 2010 6:58 pm
excellent, thanks guys. BTW I'm gunna check with a scan tool to make sure the AIR pump is what's malfunctioning does any one know off hand what code that will throw?
PostSubject: Re: need some PCM tuning Suggestions?   need some PCM  tuning Suggestions? EmptyMon Mar 08, 2010 7:49 pm
1995-1996 Chevrolet Caprice, Impala SS
with 4.3L or 5.7L Engine (VINs W, P -- RPOs L99, LT1)
Condition
· Some customers may comment of a hesitation during heavy/full throttle acceleration.
· A 1996 vehicle may also set any of the following DTCs:
o P0410
o P0412
o P1415
o P1416
o P0100
o P0101
o P0102
· A 1995 vehicle may set a DTC 48.
· There will also be evidence of water in the AIR pump.
Cause
Under high engine speed and load conditions, hot exhaust gasses may leak past the air check valves.
As the exhaust gasses in the air tube cool, water vapors collect into the AIR pump. As the vehicle is
driven, condensation from the AIR pump may come into contact with the Mass Airflow Sensor
through the AIR inlet hose. This condition may cause a hesitation on acceleration and may also set
the DTCs.
Correction
To correct this condition, a Secondary AIR Injection Pump disable procedure has been developed.
(It has been determined that the Secondary AIR Injection system is not required to meet emission
requirements for these vehicles only.)
PostSubject: Re: need some PCM tuning Suggestions?   need some PCM  tuning Suggestions? EmptyMon Mar 08, 2010 8:05 pm
Yup. Time for the delete and a trip to get it reprogrammed for the code. I'd recomend getting it proffessionally reprogrammed and then a set of headers to delete the air tubes Very Happy
LandMaster
LandMaster
PostSubject: Re: need some PCM tuning Suggestions?   need some PCM  tuning Suggestions? EmptyMon Mar 08, 2010 9:11 pm
thanks for the codes Bill I appreciate it.
Well as money comes in I'll probably go for headers. any how so in NY we have emissions garbage, I'm pretty sure they just plug into the OBD II and that tells them what they need, soo when the PCM is reprogrammed will this make it read out that it's passing?? It doens't really matter cuz my mechanic just slaps on the sticker either way. but any insight would be nice as well.
PostSubject: Re: need some PCM tuning Suggestions?   need some PCM  tuning Suggestions? EmptyTue Mar 09, 2010 3:17 pm
There's a sticker that you can order and put on the fan shroud that authorizes disabling the air pump. Some people then do a full delete without issue, while others leave the pump and plumbing just in case the tech at the inspection place is a dick.
LandMaster
LandMaster
PostSubject: Re: need some PCM tuning Suggestions?   need some PCM  tuning Suggestions? EmptyTue Mar 09, 2010 7:56 pm
Yea I saw that sticker, think I may just get that any how aswell
LandMaster
LandMaster
PostSubject: Re: need some PCM tuning Suggestions?   need some PCM  tuning Suggestions? EmptyTue Mar 09, 2010 8:55 pm
Also is any one else having a problem finding the SS tech guide?? My link to it was through geocity which i guess is gone?? I'll settle for a walk through AIR delete but if any one has a different link to the guide it'd be nice for everyone Thanks in advance.
PostSubject: Re: need some PCM tuning Suggestions?   need some PCM  tuning Suggestions? EmptyTue Mar 09, 2010 9:10 pm
Here you go. Everything you wanted to know
http://www.impalaclub.com/naisso/ss_handbook.pdf
Save yourself a copy so the link doesnt matter
LandMaster
LandMaster
PostSubject: Re: need some PCM tuning Suggestions?   need some PCM  tuning Suggestions? EmptyTue Mar 09, 2010 9:17 pm
Thanks, greatly Apreciated.
» 96 tuning??
» PCM tuning for 94/95 anyone here do it?
» Tuning at the roundup
» Tuning the supra today...
» Anyone here with obd1 tuning software?
