| opti?fuel pump? SHIT THE BED | |
+6boojum Tomz9C1 bammax Fishah mean ss BoSStonsSS 10 posters |
| Subject: opti?fuel pump? SHIT THE BED Mon Nov 23, 2009 7:57 pm | |
| was running fine all day.. when iwent to go start it up didnt want to, took awhile ..stays running but when i go to put it in drive it shuts down last week fuel line was slice by the body and had that section replaced. WHAT COULD IT BE | |
| Subject: Re: opti?fuel pump? SHIT THE BED Mon Nov 23, 2009 8:32 pm | |
| i think its the fuel pump.. the first time i turn the key i didnt hear the fuel pump prime, so i let the car run for a couple of minutes. i shut it off i took the fuel pump fuse out then put it back in , and now i hear the fuel pump and it runs fine..
is it time for a new fuel pump? | |
| Subject: Re: opti?fuel pump? SHIT THE BED Mon Nov 23, 2009 8:42 pm | |
| you could try a new relay first but you should check fuel pressure first when it dont start | |
| Subject: Re: opti?fuel pump? SHIT THE BED Mon Nov 23, 2009 9:10 pm | |
| You had a section of line replaced? Are you sure you don't have any leaks in the system?
Check fuel pressure first like Bob said. Also take a look for leaks around the repair. If no leaks and pressure is down then it's almost certainly a FP problem. | |
| Subject: Re: opti?fuel pump? SHIT THE BED Mon Nov 23, 2009 9:24 pm | |
| Don't forget to check the fuel cap. Sometimes those leak and it reduces the pressure and causes issues starting. | |
| Subject: Re: opti?fuel pump? SHIT THE BED Mon Nov 23, 2009 9:28 pm | |
| run a power wire to the fuel pump test connector "it's near the under hood fuse box" this will bye pass all fuses and relays | |
| Subject: Re: opti?fuel pump? SHIT THE BED Tue Nov 24, 2009 3:02 pm | |
| Gary Meier (LS1MM6) showed me that trick. A length of wire that will reach your +positive+ Battery terminal from that wire as shown ^^^ above. You will here it prime. | |
| Subject: Re: opti?fuel pump? SHIT THE BED Tue Nov 24, 2009 8:11 pm | |
| Reverse polarity?
You can also scan for errors. DTC16 IIRC if the opit or opti wiring is bad. Do you have a tach? If it opti or opti related you won't see any RPMs on the tach while cranking. | |
| Subject: Re: opti?fuel pump? SHIT THE BED Wed Nov 25, 2009 8:34 am | |
| Make any headway on this, Rich? Was it the FP relay? Check your grounds back there? | |
| Subject: Re: opti?fuel pump? SHIT THE BED Mon Nov 30, 2009 10:42 pm | |
| I can give you a hand with it if you need to swap it out. Just have to figure out a time that works. | |
| Subject: Re: opti?fuel pump? SHIT THE BED Mon Nov 30, 2009 11:30 pm | |
| where are you going to be 2morrow morning/afternoon? | |
| Subject: Re: opti?fuel pump? SHIT THE BED Mon Nov 30, 2009 11:51 pm | |
| IIRC it's red on the Bs. There is only one like it near that location. | |
| Subject: Re: opti?fuel pump? SHIT THE BED Tue Dec 01, 2009 12:46 am | |
| I'm going to be at the hospital tomorrow afternoon and then need to drive Laura to school from there. When's your next day off? | |
| Subject: Re: opti?fuel pump? SHIT THE BED Tue Dec 01, 2009 4:11 pm | |
| am i suppose to check the fuel pressure when the car is acting up or when it is fine?.. if I am suppose to check it when its running/or key in on position fine i got 38-40 | |
| Subject: Re: opti?fuel pump? SHIT THE BED Tue Dec 01, 2009 4:46 pm | |
| you can check now it should be 43.5 psi with vacuum line to regulator pluged engine running, racers will check theirs in 3rd at 6800 rpms,gauge taped to window if yours is at 43.5 psi you will have to test it later when it gives you a problem | |
| Subject: Re: opti?fuel pump? SHIT THE BED Tue Dec 01, 2009 4:49 pm | |
| its at 38-40 psi runnning connected to the schrader valve.. | |
| Subject: Re: opti?fuel pump? SHIT THE BED Tue Dec 01, 2009 4:55 pm | |
| you need to take the vacuum line off the fuel pressure regulator to check
does it start better after you played with the fuse? | |
| Subject: Re: opti?fuel pump? SHIT THE BED Tue Dec 01, 2009 7:29 pm | |
| Dont you LOVE has an intermittent problem. FP does that, so do many other things Did you say the fuel filter has been replaced? Silly but also easy (unless you find cancerous brake line back there uughh) Did you check the grounds in the trunk? Have you seen the harness by the tank? I say screw it, tape the gauge to the windshield & drive laps locally. Everytime you get home turn it off & on til the problem shows its ugly side. Have you taken it out & beat the piss outta it? WOT stuff? Did you spray the MAF? check all vacuum lines & wiring Did you get a maintenace record guestimate from Doug? I was begging for answers when my car was abusing me | |
| Subject: Re: opti?fuel pump? SHIT THE BED Wed Dec 02, 2009 6:30 am | |
| So early morning 12am heading to work i start my car , i dont hear the fuel pump. but of course i cant test pressure because i have o be at work at 1215am.(so running late) So I get off work..check the imp out no priming and i check the pressure and its 10psi .. looks like i'll be getting that racetronix fuel pump for $170 because i will be adding more mods to the imp.. if anyone has any fuel pump suggestions let me kno ASAP.... 857-204-3670 Rich | |
| Subject: Re: opti?fuel pump? SHIT THE BED Wed Dec 02, 2009 7:00 am | |
| - BoSStonsSS wrote:
- So early morning 12am heading to work i start my car , i dont hear the fuel pump. but of course i cant test pressure because i have o be at work at 1215am.(so running late)
if anyone has any fuel pump suggestions let me kno ASAP.... 857-204-3670 Rich Make sure to upgrade the harness as well, and replace the sock, and inline filter. |
| Subject: Re: opti?fuel pump? SHIT THE BED Wed Dec 02, 2009 7:36 am | |
if anyone has any fuel pump suggestions let me kno ASAP.... 857-204-3670 Rich Make sure to upgrade the harness as well, and replace the sock, and inline filter. doesnt all of that come with the walbro 255 kit? http://www.racetronix.biz/customkititems.asp?kc=RFPK%2D004&eq= | |
| Subject: Re: opti?fuel pump? SHIT THE BED Wed Dec 02, 2009 9:12 am | |
| Dont know if this link will be any help but if your alone, it may give you a couple of pointers. https://badass-of-ne.forumotion.com/problems-maintenance-f4/quick-fuel-pump-swap-t712.htm?highlight=fuel+pump1) Check it out & use PC blaster a day or so BEFORE you do the job That way if you need hardware, straps,fuel lines you'll have them (Crovo was 100% right when he said the fuel line connectors can be a problem) 2) Relieve fuel pressure. Either way when you disconnect the feed & return lines it'll try to piss in your eye 3) Make sure you have no gas (at least after you remove it) Gas in tank=PIA 4) Make sure you tie a pull string (good quality tough line) to the old harness when removing. I didnt upgrade this on my 95 just a suggestion from years of pulling cable 5) Dont forget the fuel filler neck bolts behind the license plate 6) Beg for help cause then someone can hear you when you complain | |
| Subject: Re: opti?fuel pump? SHIT THE BED Wed Dec 02, 2009 5:48 pm | |
| I didn't see this before Rich, Just FYI if you did not see it from the records and when you looked underneath, the fuel filter was done this past summer and the rear brake line showed it's rusty head at that time and was replaced as well. That's about all I can recall for fuel related things.
I hate that it is doing this to you because it NEVER ever gave me any issues like that, sucks dude.
Good luck with everything
Doug | |
| Subject: Re: opti?fuel pump? SHIT THE BED Wed Dec 02, 2009 6:34 pm | |
| you might want this to BLT1 Bulkhead Connector Assembly
http://www.racetronix.biz/printitem.asp?Source=CK&ic=BTL1%2DBCA | |
| Subject: Re: opti?fuel pump? SHIT THE BED Wed Dec 02, 2009 10:04 pm | |
| Rich is a jinx. Once he owns a car everything goes wrong with it Rich I pm'ed you. I have all the tools you need for the job. I just need to find them | |
| Subject: Re: opti?fuel pump? SHIT THE BED Wed Dec 02, 2009 10:08 pm | |
| you would I'm just messin with ya I'll check the schedule and get back to you | |
| Subject: Re: opti?fuel pump? SHIT THE BED Wed Dec 02, 2009 10:14 pm | |
| Subject: Re: opti?fuel pump? SHIT THE BED Thu Dec 03, 2009 4:14 pm | |
| Subject: Re: opti?fuel pump? SHIT THE BED Fri Dec 04, 2009 11:00 am | |
| Rich, Ron had sent me this link back in August, it's since updated but was fast delivery Back then it was $59 & it said make me an offer I offered $45 & he took it I was just throwing $ at the job to make it go away The width of the strap at the rear of the car is about 1/16-1/8 to wide Grind down before paint & your good to go http://cgi.ebay.com/ebaymotors/RST186-1991-1996-BUICK-ROADMASTER-GAS-TANK-STRAPS_W0QQitemZ120486116836QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item1c0d883de4 | |
| Subject: opti? fuel pump? shit the bed Fri Dec 04, 2009 1:46 pm | |
| rich. there now down to $49.00. or best offer. good luck with the job. hope that fixes the problem. dont forget the pics. i cant post. but i like looking at them. | |
| Subject: Re: opti?fuel pump? SHIT THE BED Fri Dec 04, 2009 10:30 pm | |
| Subject: Re: opti?fuel pump? SHIT THE BED Fri Dec 04, 2009 10:52 pm | |
| Glad it worked out for you. Sorry I couldn't be there to help. I was elbow deep in the Omega today so it just wasn't going to happen. I'll do my best to help out next time you break something. It shouldn't take long | |
| Subject: Re: opti?fuel pump? SHIT THE BED Sun Dec 06, 2009 2:11 pm | |
| SMELLING GAS!!! I TIGHTENED THAT EVAP HOSE THAT WOULD CAUSE THAT.. STILL SMELLING IT
WHAT CAN BE THE PROBLEM? | |
| Subject: Re: opti?fuel pump? SHIT THE BED Sun Dec 06, 2009 2:35 pm | |
| you might need a new o-ring in the fuel lines | |
| Subject: Re: opti?fuel pump? SHIT THE BED Sun Dec 06, 2009 7:23 pm | |
| If you can smell it you should be able to see it Check both ends, fuel filter & there's 1 more between the filter & the front but I've never seen it (somewhere below the A pillar at the frame?) Didnt you say you had a repair done? Sniff it out | |
| Subject: Re: opti?fuel pump? SHIT THE BED Wed Dec 09, 2009 12:15 pm | |
| FIGURE OUT WHERE THE SMELL IS COMING FROM.. THE IDIOT THAT DOUG GOT THE CAR FROM DRILL A SCREW IN THE GAS TANK TO MOUNT THE SUBWOOFER.. SO I GUESS WHEN I DROPPED AND PUT IT BACK MUSTVE MADE A BIGGER HOLE.. SMH WHAT NEXT!!!!! | |
| Subject: Re: opti?fuel pump? SHIT THE BED Wed Dec 09, 2009 12:43 pm | |
| Well How could you know? At least your now certified & you know the hardware is fresh JB Weld FTW I bet Brad will be available this time now that its snowy & freezing | |
| Subject: Re: opti?fuel pump? SHIT THE BED Wed Dec 09, 2009 12:50 pm | |
| I knew because i sniffed and felt around in the trunk and saw it wet but the screw. i have jb weld but i will not be dropping the tank its too shitty out... jus gonna see how much a shop will do to drop it | |
| Subject: Re: opti?fuel pump? SHIT THE BED Wed Dec 16, 2009 12:36 pm | |
| WTF!!!! Nowwww. Don't hear fuel pump priming. When I put the hazards on the car it drives.
What are the three hoses that connect to the fuel pump. The3rd hose to the right. | |
| Subject: Re: opti?fuel pump? SHIT THE BED Wed Dec 16, 2009 2:24 pm | |
| 3/8 feed 5/16 return 3/8 vent Thats not your problem. No prime = electrical How did you ever figure out your hazzards start the car WTF??? Maybe a grounding issue? Unplug your harness under the tank & check with multimeter Whichever is ground should be 0 continuity ALL the time | |
| Subject: Re: opti?fuel pump? SHIT THE BED Wed Dec 16, 2009 2:31 pm | |
| Subject: Re: opti?fuel pump? SHIT THE BED Wed Dec 16, 2009 3:16 pm | |
Unplug your harness under the tank & check with multimeter Whichever is ground should be 0 continuity ALL the time I ef'd up here it should HAVE continuity ALL the time 1 side if meter to harness (car side not tank side) other side to good ground meter should read the same as touching the 2 sides of the meter together (in ohms setting) | |
| Subject: Re: opti?fuel pump? SHIT THE BED Wed Dec 16, 2009 9:31 pm | |
| Fuel pump and tail lights are some how connected. My blinker and brake lights make my pump whine change pitch. I'd say the spot where the systems connect is the spot that's screwing you right now. | |
| Subject: Re: opti?fuel pump? SHIT THE BED Wed Dec 16, 2009 10:14 pm | |
| I'm pretty sure the fuel pump/sender uses the ground in the trunk on the left up under by the hinge. that ground should be the same in the harness (plug) to sender connection Check that wiring | |
| Subject: Re: opti?fuel pump? SHIT THE BED | |
