| OOPS. Make sure you Torgue those Bolts. | |
| Subject: OOPS. Make sure you Torgue those Bolts. Sun Aug 09, 2009 7:31 pm | |
| I went to Jims last weekend to try to align my front end as its got a shimmy at 65/70. Well we managed to get the wheels fairly close to straight.But the shimmy was still there. A couple of days ago i pull into my driveway and hear a louder than usual clunk from the rear end. I look underneath and see this. Looks like i didn't get the nuts tight enough when i installed the shocks. Being the pack rat that i am i still had the hardware from the old shocks. Managed to get it back into the hole and tightened but i think the shaft is bent a little. Shimmys not completly gone but it's not as bad. Thank god it happened in the driveway not on the highway. | |
Deputy347K9
Posts : 147 Join date : 2009-04-05 Location : Limington, Maine
| Subject: Re: OOPS. Make sure you Torgue those Bolts. Tue Nov 17, 2009 8:01 am | |
| Mark:
Loose nuts is the number one cause of unexpected problems all around the world! Keep your nuts tight and in good order and your day will go much better!
Larry | |
| Subject: Re: OOPS. Make sure you Torgue those Bolts. Tue Nov 17, 2009 9:23 am | |
| At least you don't have a screw loose. lol! I had that happen to the front shocks on my ghey blue 9C1. I phucked up the other shock because I didn't catch it right off. I couldn't even remember who installed them. I'm bad about that. | |
| Subject: Re: OOPS. Make sure you Torgue those Bolts. Tue Nov 17, 2009 9:56 am | |
| People waited until now to make jokes about Mark's missing nuts and his bent shaft? He did make his post in August by the time stamp, so I guess that means you guys really don't care as much about your friends nuts bouncing down the road as you pretend to Now there's a visual you won't get out of your head for a while | |
| Subject: Re: OOPS. Make sure you Torgue those Bolts. Tue Nov 17, 2009 1:55 pm | |
| ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ I like him. He's funny |
| Subject: Re: OOPS. Make sure you Torgue those Bolts. Tue Nov 17, 2009 2:08 pm | |
| I found Marks inspiration https://www.youtube.com/watch?v=bOTSk7A6dyU Sorry Mark but this is just such an easy topic to act stupid with. Maybe it should be a sticky. Then it would be a sticky nut post | |
Deputy347K9
| Subject: Re: OOPS. Make sure you Torgue those Bolts. Tue Nov 17, 2009 5:46 pm | |
| https://www.youtube.com/watch?v=EsDFztunTmI
Not sure if I am posting the above properly, we will try it! Just for Mark! | |
| Subject: Re: OOPS. Make sure you Torgue those Bolts. Tue Nov 17, 2009 6:11 pm | |
| - Deputy347K9 wrote:
- https://www.youtube.com/watch?v=EsDFztunTmI
Not sure if I am posting the above properly, we will try it! Just for Mark! Ya sick prick .How is it a guy who can't post a simple picture.can post that sh*t up? I will admit I laughed. | |
| Subject: Re: OOPS. Make sure you Torgue those Bolts. Tue Nov 17, 2009 6:47 pm | |
| Aaaawwwww dude | |
| Subject: Re: OOPS. Make sure you Torgue those Bolts. Tue Nov 17, 2009 7:07 pm | |
Not sure if I am posting the above properly, we will try it! Just for Mark! Ya sick prick .How is it a guy who can't post a simple picture.can post that sh*t up? I will admit I laughed. I was thinking the same thing Mark. And what the hell are you doing on youtube looking at nutz for anyways Larry? |
| Subject: Re: OOPS. Make sure you Torgue those Bolts. Wed Nov 18, 2009 8:30 am | |
| Subject: Re: OOPS. Make sure you Torgue those Bolts. | |
