Map Lights??? EmptyWed Oct 19, 2022 1:27 pm by scot
Map Lights??? EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Map Lights??? EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Map Lights??? EmptyFri Sep 24, 2021 9:53 am by ElKy
Map Lights??? EmptySun Sep 19, 2021 6:22 pm by black blur 96
Map Lights??? EmptySun Jun 20, 2021 11:37 am by scot
Map Lights??? EmptyFri Jun 11, 2021 10:41 am by scot
Map Lights??? EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Map Lights??? EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
 Map Lights???
3 posters
Map Lights??? Empty
PostSubject: Map Lights???   Map Lights??? EmptyTue Nov 10, 2009 2:40 pm
Is ther a fuse for the map lights if so where because i think i blew it Embarassed
Map Lights??? Empty
PostSubject: Re: Map Lights???   Map Lights??? EmptyTue Nov 10, 2009 3:03 pm
You just got the car and your already breaking things? At least try to keep everything attatched this time. No more stuffing random speakers in random places Razz
Map Lights??? Empty
PostSubject: Re: Map Lights???   Map Lights??? EmptyTue Nov 10, 2009 3:10 pm
LOL @ stuffing speakers lmao.. i was installing the l.e.ds in i pulled the wire a bit hard , so i try to plug back and it just turned offf.
Map Lights??? Empty
PostSubject: Re: Map Lights???   Map Lights??? EmptyTue Nov 10, 2009 5:41 pm
DUMBASS! Razz
There is a fuse, and a relay. The relay is way back near the fire wall by the steering column inside the car, and the fuse is in the panel on the drivers side of the dash. It should be the left one or the middle one. Fuse door will tell where the fuse is. To see if the relay is bad, just turn on the int lights from the dash switch. If the lights come on, then it is the relay. If nothing, look for the fuse.
Map Lights??? Empty
PostSubject: Re: Map Lights???   Map Lights??? EmptyTue Nov 10, 2009 6:33 pm
Lmao thanks Billy
Map Lights??? Empty
PostSubject: Re: Map Lights???   Map Lights??? EmptyTue Nov 10, 2009 7:36 pm
BoSStonsSS wrote:
Lmao thanks Billy
Wink
Map Lights??? Empty
PostSubject: Re: Map Lights???   Map Lights??? EmptyTue Nov 10, 2009 11:33 pm
Can't leave well enough alone can ya? Map Lights??? Icon_lol Seriously, glad to see you are making it your own. It was pretty cool to see it fallowing me as your were leaving with the HIDs.
Map Lights??? Empty
PostSubject: Re: Map Lights???   Map Lights??? EmptyWed Nov 11, 2009 1:06 am
there's nothing I can really do to this car it's perfectttttt.. I am going to lower it though in the spring.
Map Lights??? Empty
PostSubject: Re: Map Lights???   Map Lights??? EmptySun Nov 15, 2009 4:55 pm
Interior lights won't shut off. I took the interior lights relay out so it will go out. What can be the problem? Need a new relay?
Map Lights??? Empty
PostSubject: Re: Map Lights???   Map Lights??? EmptyMon Nov 16, 2009 2:34 pm
Mine did that and it turned out the door jam switch in the drivers door was loose. I tightened it up and everything is fine now.
Map Lights??? Empty
PostSubject: Re: Map Lights???   Map Lights??? EmptyMon Nov 16, 2009 3:45 pm
yea it wasnt that.. it was the #35 fuse
Map Lights??? Empty
PostSubject: Re: Map Lights???   Map Lights??? EmptyMon Nov 16, 2009 3:47 pm
So all is fixed now? Hopefully there are no other issues to deal with for a while.
Map Lights??? Empty
PostSubject: Re: Map Lights???   Map Lights??? EmptyMon Nov 16, 2009 3:49 pm
yup!!!!!!!!
Map Lights??? Empty
Map Lights???
» DDM lights
» tail lights
» 96 PCM, RMS Tail Lights
» Listed my t-84 lights
» Using hazard lights
