| Map Lights??? | |
| Subject: Map Lights??? Tue Nov 10, 2009 2:40 pm | |
| Is ther a fuse for the map lights if so where because i think i blew it | |
| Subject: Re: Map Lights??? Tue Nov 10, 2009 3:03 pm | |
| You just got the car and your already breaking things? At least try to keep everything attatched this time. No more stuffing random speakers in random places | |
| Subject: Re: Map Lights??? Tue Nov 10, 2009 3:10 pm | |
| - bammax wrote:
- You just got the car and your already breaking things? At least try to keep everything attatched this time. No more stuffing random speakers in random places
LOL @ stuffing speakers lmao.. i was installing the l.e.ds in i pulled the wire a bit hard , so i try to plug back and it just turned offf. | |
| Subject: Re: Map Lights??? Tue Nov 10, 2009 5:41 pm | |
| - BoSStonsSS wrote:
LOL @ stuffing speakers lmao.. i was installing the l.e.ds in i pulled the wire a bit hard , so i try to plug back and it just turned offf. DUMBASS! There is a fuse, and a relay. The relay is way back near the fire wall by the steering column inside the car, and the fuse is in the panel on the drivers side of the dash. It should be the left one or the middle one. Fuse door will tell where the fuse is. To see if the relay is bad, just turn on the int lights from the dash switch. If the lights come on, then it is the relay. If nothing, look for the fuse. |
| Subject: Re: Map Lights??? Tue Nov 10, 2009 6:33 pm | |
| Subject: Re: Map Lights??? Tue Nov 10, 2009 11:33 pm | |
| Can't leave well enough alone can ya? Seriously, glad to see you are making it your own. It was pretty cool to see it fallowing me as your were leaving with the HIDs. Doug | |
| Subject: Re: Map Lights??? Wed Nov 11, 2009 1:06 am | |
| - Pooge wrote:
- Can't leave well enough alone can ya? Seriously, glad to see you are making it your own. It was pretty cool to see it fallowing me as your were leaving with the HIDs.
Doug there's nothing I can really do to this car it's perfectttttt.. I am going to lower it though in the spring. | |
| Subject: Re: Map Lights??? Sun Nov 15, 2009 4:55 pm | |
| Interior lights won't shut off. I took the interior lights relay out so it will go out. What can be the problem? Need a new relay? | |
| Subject: Re: Map Lights??? Mon Nov 16, 2009 2:34 pm | |
| Mine did that and it turned out the door jam switch in the drivers door was loose. I tightened it up and everything is fine now. | |
| Subject: Re: Map Lights??? Mon Nov 16, 2009 3:45 pm | |
| yea it wasnt that.. it was the #35 fuse | |
| Subject: Re: Map Lights??? Mon Nov 16, 2009 3:47 pm | |
| So all is fixed now? Hopefully there are no other issues to deal with for a while. | |
| Subject: Re: Map Lights??? Mon Nov 16, 2009 3:49 pm | |
| Subject: Re: Map Lights??? | |
| Map Lights??? | |
