February 2018
 MA inspection
Detroit Steel
PostSubject: MA inspection   Thu Nov 05, 2009 9:04 pm
My 85 Olds has 35% tint, shop says its reading 31% on the meter. They won't pass it as is. I dunno what the issue is as the last 3 years the car has passed fine.
Anyone know a MA shop that won't jerk me on the little things like...being 4% over the tint limit?
thank you!
PostSubject: Re: MA inspection   Thu Nov 05, 2009 9:15 pm
Where in Mass are you?
Detroit Steel
PostSubject: Re: MA inspection   Thu Nov 05, 2009 9:25 pm
North of Boston along 93, close to the NH border.
onehunglo
PostSubject: Re: MA inspection   Thu Nov 05, 2009 10:46 pm
Could try Bradford Towing over in Haverhill, I think they give stickers, I know they have Mob connects Cool
PostSubject: Re: MA inspection   Fri Nov 06, 2009 8:42 am
Hey Dan, what's up? You found us! You still have that old 9c1?
I can't help you with a sticker in Ma though. Took me about 14 months to get my Impala legal when I moved there! Evil or Very Mad
PostSubject: Re: MA inspection   Fri Nov 06, 2009 11:17 am
come down to boston and go to any shop they should past you easy... i dont think they check tints( my budy had 87 caprice 15% all around jus scanned the door vin , checked horn, seatbelts and he was all set)
PostSubject: Re: MA inspection   Fri Nov 06, 2009 12:50 pm
I know a guy that's pretty easy going but he's quite a ways south of you Neutral
I could also direct you to a guy who will fail a brand new car if his garage is empty and he needs some "repair" work Twisted Evil
Detroit Steel
PostSubject: Re: MA inspection   Fri Nov 06, 2009 5:25 pm
I was able to find a shop in Lowell today. They said it passed on thier gun anyway. Other shops who checked it said their gun was reading anywhere between 27% and the 35% limit. Shows just how out of whack the testing tools in this state are.
And yes Mr. Crovo I was pointed in the direction of this forum. I still have the 9C1 but it is going buh-bye very soon. After 4 different shops had it no one could fix it. Expect to see some parts for sale soon.
PostSubject: Re: MA inspection   Fri Nov 06, 2009 5:31 pm
Glad you got it inspected! Smile
And... What's wrong with the 9c1?
Detroit Steel
PostSubject: Re: MA inspection   Fri Nov 06, 2009 7:17 pm
Random stalling. Would run rough, then good...randomly. Would drive for 3 days fine then suddenly die. Sometimes would run fine again after 30 minutes.
Replaced plugs, wires, coil, opti, swapped PCM once.... nothing worked.
It has been sitting for months.
PostSubject: Re: MA inspection   Sat Nov 07, 2009 12:15 pm
How's the fuel pressure when it's not running? Or could the shops not duplicate it? Sounds like a bad fuel pump to me. That's what it did in Morticia when it went. If it's not running now, switch the key to "run" and listen for the fuel pump. It only primes for a few seconds, so you may want to have someone near the tank listening.
MA inspection
» Kit 8 water tank inspection cover
» Root over rock/Clinging to rock- watering and inspection of planting made easy.
» My first speeder (draisine), guess it's yellow
» ABS Light, Three Amigos & the ABS Amigo (disco 2)
» Safety Valve -inspection failure
