Do all of these cars have the same rear end housing? EmptyWed Oct 19, 2022 1:27 pm by scot
Do all of these cars have the same rear end housing? EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Do all of these cars have the same rear end housing? EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Do all of these cars have the same rear end housing? EmptyFri Sep 24, 2021 9:53 am by ElKy
Do all of these cars have the same rear end housing? EmptySun Sep 19, 2021 6:22 pm by black blur 96
Do all of these cars have the same rear end housing? EmptySun Jun 20, 2021 11:37 am by scot
Do all of these cars have the same rear end housing? EmptyFri Jun 11, 2021 10:41 am by scot
Do all of these cars have the same rear end housing? EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Do all of these cars have the same rear end housing? EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
4 posters
PostSubject: Do all of these cars have the same rear end housing?   Do all of these cars have the same rear end housing? EmptyMon Nov 02, 2009 8:32 pm
Do all of the B body cars have the same rear end? I know the gears may be different but the housings are the same? Trying to figure out exactly what to look for when buying gears. Any info would be helpful. Thanks guys......... What a Face
PostSubject: Re: Do all of these cars have the same rear end housing?   Do all of these cars have the same rear end housing? EmptyMon Nov 02, 2009 8:40 pm
Nope. Every model is slightly different.
The wagons have different suspension mounts from the sedan to accomodate the different fuel tank.
The 9c1's have shorter axle shafts to allow the use of snow chains without hitting the inner fenders.
The L99 cars have a 7.5" rear instead of the standard 8.5".
The SS and 9c1's have disk brakes as oppossed to the standard drums.
If any of that is confusing then just remember that the ss and 9c1 rears are good and the rest suck Wink
PostSubject: Re: Do all of these cars have the same rear end housing?   Do all of these cars have the same rear end housing? EmptyMon Nov 02, 2009 9:50 pm
I guess what I'm looking for is info on what 3:73 gears will work in my rear end. What a Face
PostSubject: Re: Do all of these cars have the same rear end housing?   Do all of these cars have the same rear end housing? EmptyMon Nov 02, 2009 10:23 pm
There are only two versions of the rear end housing itself. (The Pumpkin)
The 7.5 inch version
The 8.5 inch version
ALL LT1 and 5.7 cars came with the 8.5
If your car is an LT1, the rear is an 8.5 inch, 30 spline, 10 bolt.
www.clearimageautomotive.com
They've got the gears.
PostSubject: Re: Do all of these cars have the same rear end housing?   Do all of these cars have the same rear end housing? EmptyTue Nov 03, 2009 6:32 am
All 9C1s came with the 8.5 regardless of engine. And 3.23s standard and possibly posi if it was a L99 car. cheers
PostSubject: Re: Do all of these cars have the same rear end housing?   Do all of these cars have the same rear end housing? EmptyTue Nov 03, 2009 11:53 am
NYPD Had mostly L99 cars.
» Kit Cars
» Cars on map
» Highways and Backroads: Spot a B or D today? Post a Pic
» New Sema cars
» cars gone...
