 93 T56 info needed.
PostSubject: 93 T56 info needed.   Thu Oct 15, 2009 2:59 pm
There is a complete T/A with a T56 available that I would love to go get tomorrow, but it is a 93 and I am not well versed on them as a swap tranny in a B body. I understand they are geared different and rated for a bit less HP, but I'm wondering if anyone has any real world experience?
This would be going into a box Caprice project. From what I have read 3.73 gears is the way to go, but will this thing stand up to a healthy 350-375 HP LT1? I want a fast 0-60 and could care less about anything after that, other than that the 3.73 and 6 speed should work out to pretty nice highway cruising mileage...
Thanks,
PostSubject: Re: 93 T56 info needed.   Thu Oct 15, 2009 6:02 pm
It has a lower torque rating, but has a desirable gearset IF it is the optional M29 93-only tranny. Wink It's 3.73-friendly, too. So you most likely won't have to worry about vibrations.
Either way, I would run one in my shit. Smile
PostSubject: Re: 93 T56 info needed.   Thu Oct 15, 2009 7:15 pm
There were two different trannys for '93.
I found this:
1993 Manual/M28 3.36 2.07 1.35 1.00 0.80 0.62
1993 Manual/M29 2.97 2.07 1.43 1.00 0.80 0.62
1994 Manual/MN6 2.66 1.78 1.30 1.00 0.74 0.50
I'll leave it up to the reader to determine what the casting numbers are for each. Smile
If it's a good price grab it!
PostSubject: Re: 93 T56 info needed.   Thu Oct 15, 2009 7:44 pm
Thanks guys, so what is the deal with the M28? Assuming it is not the M29 is it worth my time?
I assume M29 would be on the spid label? Am I correct to assume it is on the trunk on these like our cars?
PostSubject: Re: 93 T56 info needed.   Thu Oct 15, 2009 10:40 pm
Yes M29 or M28 should be on the SPID label.
If you decide to pass let me know. I'd also risk the lower torque rating. 'sides I have some other lighter weight projects in mind.
Year Model/Optn 1st 2nd 3rd 4th 5th 6th Final
1993 Manual/M28 3.36 2.07 1.35 1.00 0.80 0.62 2.73 (GU2)
1993 Manual/M29 2.97 2.07 1.43 1.00 0.80 0.62 3.23 (GU4)
1994 Manual/MN6 2.66 1.78 1.30 1.00 0.74 0.50 3.42 (GU6)
Year Model/Optn Torque Capacity
1993 Manual/M28 360 lbs-ft
1993 Manual/M29 400 lbs-ft
1993 Auto/MX0 400 lbs-ft*
1994 Manual/MN6 450 lbs-ft
1994 Auto/MX0 400 lbs-ft*
*According to the GM Powertrain divison, the maximum torque the 4L60E transmission can handle is 350 lbs-ft of torque.
PostSubject: Re: 93 T56 info needed.   Fri Oct 16, 2009 8:38 am
DAMN, the guy took a deposit through paypal last night...should have asked these questions BEFORE I found a car... Oh well, there will be more.
Thanks for all the info guys!
PostSubject: Re: 93 T56 info needed.   Sun Oct 25, 2009 9:35 am
jlehlein posted a spreadsheet on that other forum that might interest you.
93 T56 info needed.
» Line Lock Info needed
» Grundig info needed
» Heathkit IM-105 Schematic & Cal Info Needed
» Rare Record Info Needed
» Bought a Latino ST-120 and need info.
