 Is My trans case toast?
PostSubject: Is My trans case toast?   Sat Sep 12, 2009 10:56 am
PostSubject: Re: Is My trans case toast?   Sat Sep 12, 2009 4:23 pm
May not be the same as your truck but on the blazer the front driveshaft always turned, but the front gears locked and unlocked based off a cable running from a vaccuum canister under the battery tray. To manually disengage the front wheels we would unhook the vaccuum to the canister.
» The Curious Case of Benjamin Button
» Pot holder rotary cutter case
» 2004 GTO - $5900 needs trans
» Trans diptstick leak
» Superman Case With The Shuster/Siegel Estates
