Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1 EmptyWed Oct 19, 2022 1:27 pm by scot
Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1 EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1 EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1 EmptyFri Sep 24, 2021 9:53 am by ElKy
Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1 EmptySun Sep 19, 2021 6:22 pm by black blur 96
Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1 EmptySun Jun 20, 2021 11:37 am by scot
Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1 EmptyFri Jun 11, 2021 10:41 am by scot
Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1 EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1 EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
4 posters
PostSubject: Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1   Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1 EmptyThu Aug 27, 2009 2:39 pm
Twice before I had problems with a LT1 knocking, pinging and loss of power only after the car warms up.
Twice I have replaced the optisaprk and problem solved.
Now I have the same problem with the Camaro only worse. This car has the nonvented version of the opti. So is it the cap or the electronics gone bad? To play it safe I plan to take the MSD cap from the spare engine and the base with electronics from the Z28 parts car. Now the unvented optis cost around $100 more than the vented version and have about 1/10th the lifespan.You can modify the unvented optis to vented with a couple fittings, a drill, and some glue.
OK now the trouble starts. Smile I decide to replace the water pump shaft seal 'casue it's much much more difficult to replace the opti in the F-Bodies and I really don't want to have to do this again for a long time. Now I've replaced this seal almost as many times as Bill's Nephew has installed trannys without any trouble. Not this time I wreck the seal twice. So after three trips to the parts store I get the seal installed correctly.
Now the real trouble starts. I take the two opti halves and put them together to make one. Mod it to make it into a vented version. Put everything back together, fill 'er up with coolant and try to start the car. It won't start. WTF! I scan for codes and get a DTC 16, no low resolution signal. Now it can't be the cap because it shouldn't cause this kind of error. It can't be the opti base and electronics 'cause the engine it came from was running last week. I start checking the wiring and what not. I can't find anything wrong and now I'm getting really pissed. I decide it has to be the opti electronics as strange as it seems.
I'm out of junk optis and I really don't have the money to pop for a new one due to some of my recent purchases. I have a buch o' spare parts but it seems almost never exactly what I need. I decide to try the original opti base and electronics with the MSD cap. Put it all back together sans coolant 'cause I don't have anymore antifreeze. Try to start the car and it fires right up. At this point I'm still not sure the original problem it solved since I can't let it warm up. Off to Walmart for more antifreeze. As soon as I get back I find a full jug in the garage that I thought was water. Smile Fill it up, warm it up and all seems fine. Now how did the opti from the Z28 parts car go bad when it ran just last week?
From a visual inspection it's obvious the original cap was bad. I still fear there may be a problem and I won't be happy 'til I run the car for an extended period of time.
Does anyone have any personal experience with the ultra cheap ebay optis? I'm gonna need another if I try to fire up the Z28 engne.
How much do distributors cost for the LS1 engines?
PostSubject: Re: Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1   Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1 EmptyThu Aug 27, 2009 6:29 pm
how is the opti wiring harness?
opti, used 40 miles http://www.camaroz28.com/forums/showthread.php?t=707639
PostSubject: Re: Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1   Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1 EmptyThu Aug 27, 2009 6:47 pm
YES! STRANDED ME ON I-895 in Charlotte,NC. July, 1st 2008! I'm not bitter though.
PostSubject: Re: Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1   Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1 EmptyThu Aug 27, 2009 7:58 pm
I think I would like to make this a one time fix.
I would buy a brand new ac delco opti from summit or jegs.I would drill, tap and install a port so the damn thing can be vented.
I would then use the msd cap and rotor if it fits, and purchase a new vent harness and opti harness, and never look back.
PostSubject: Re: Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1   Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1 EmptyThu Aug 27, 2009 9:53 pm
The harness is fine. I tried another just in case.
Hey you can see through that opti!
Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1 3858593985_c97d075620_b
The GM unvented opti form Summit is $400!
I modded the previous opti to be vented. The vented caps fit just fine. I might just see if I can get something cheap (used Gm) and order an Accel cap from Summit. I could always change the cam.
PostSubject: Re: Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1   Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1 EmptyFri Aug 28, 2009 6:02 am
I have never seen the internals of an early opti. I am only aware of the drive and vent differences. Could you use the magnetic pick up from the newer style? What else about it could fail? Just put the late pickup in your old style opti body, and not buy a whole unit.
I have come to the conclusion that the optispark, 4l60e, heating system, and intake gaskets were designed at 4pm on a friday befor a long weekend. scratch
PostSubject: Re: Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1   Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1 EmptyFri Aug 28, 2009 7:18 am
Not to mention grade "5" Exhaust manifold bolts.
PostSubject: Re: Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1   Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1 EmptyFri Aug 28, 2009 8:44 pm
I dont want to tell you something you already know but the temp sensor on the waterpump will stop that vehicle from running when its hot
It'll start when you MAKE it but it'll sputter & miss whenever it decides.
Cheap fix (especially when there's no antifreeze in there Laughing )
PostSubject: Re: Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1   Dr. Optispark or: How I Learned to Stop Worrying and Love the LT1 EmptySat Sep 05, 2009 7:22 pm
Just for fun today I replaced the new opti seal that was leaking. I should have left that one alone too since the original wansn't leaking. Smile
I think I should start saving for a LSx.
» How I Learned to Stop Worrying and Make a 9C1 Clone of the SS
» Anyone know how to stop a po131 code?
» Learned Why My Tire Kept Going Flat...
» Oil leak won't stop!
» B body die cast and related collectables
