March 2018
 Spaced Out Coil
PostSubject: Spaced Out Coil   Mon Aug 24, 2009 9:09 pm
Does anyone space the coil/ICM away from the head?
The Camaro is like this, done by the previous owner.
Ain't the problem anyway. Looks like time for a new opti. Either a used one I already have or a $60 Accel cap from Summit.
PostSubject: Re: Spaced Out Coil   Mon Aug 24, 2009 9:20 pm
I saw a pic of the ICM relocated up front on the rad support.
Think it needs heat grease tho.
If you space it it still should throw heat I'd think
95 Black WB4
95BBB 189K 3.08 Old DD Matt. Cool
PostSubject: Re: Spaced Out Coil   Tue Aug 25, 2009 5:31 am
The accel cap is a nice piece. I have used it. And like the msd unit, it uses brass instead of aluminum.
PostSubject: Re: Spaced Out Coil   Wed Aug 26, 2009 10:27 pm
Some of the F-body folks do this. They put the coil/ICM 1 nut away from the head. The idea being that no need to pick up heat from the head and it sure ain't acting as a heat sink. Seems to be working fine so I'll just leave it the way it is.
More on the optispark horror later. It aint over yet.
Spaced Out Coil
» Tell me about indexing coil springs?
» Need advice with drilling aluminum for tapping and heli-coil
» Bailey LTCC coil on plug conversion.
» Spaced Invaders
» Morris Coil Winder info
