| Subject: 94 Camaro LT1 short block - $200 Wed Aug 19, 2009 11:06 pm | |
| I have a complete short block from a 94 Camaro for sale if anyone needs it or knows someone. I just took the heads off this past weekend. Approx. 115K miles (was transplanted into a Jeep at around 100K miles) It is clean and in great shape with good cylinder walls. Running when pulled by a buddy, I saw this motor run very well in his Jeep 6 months ago before he pulled it to rebuild and found a new project. I also have many stock LT1 parts and accessories from the same motor that will be available at a very discounted rate if you purchase the short block. (including Opti, manifolds, starter, accessory bracket, intake, PCM, fuel rails, etc) $200 firm for the short block... I can deliver Saturday to Crovos or depending on location (And if I make it to pick up a car in SE Mass) maybe we can meet up Saturday or Sunday on my way to pick up the car, otherwise pickup only in Walpole, NH or Claremont, NH whichever is closer for you. Thanks, Doug | |
