 found the problem.
PostSubject: found the problem.   Mon Aug 03, 2009 9:29 pm
As some of you know, I put a junk yard LT1 in my wagon last year. After a week, I had an engine noise and had to get another engine. I found the problem.
Installing replacement engine
http://www.impalassforum.com/vBulletin/showthread.php?t=201304
Replacement engine failure
http://www.impalassforum.com/vBulletin/showthread.php?t=205552
Second replacement engine
http://www.impalassforum.com/vBulletin/showthread.php?t=206517
This is what I found yesterday. Number 7 spun one fo sho!
PostSubject: Re: found the problem.   Mon Aug 03, 2009 9:58 pm
That's a good bit of damage there. What was the cause of the spun bearing? Did you forget the oil Wink
PostSubject: Re: found the problem.   Tue Aug 04, 2009 5:48 am
Damn, that sucks. Just what you need another project.
Time to send Doug out with a mission
PostSubject: Re: found the problem.   Tue Aug 04, 2009 9:22 am
Hi Bill
This is the old problem from the wagon, right; not a new problem from the Impala, I hope?
PostSubject: Re: found the problem.   Tue Aug 04, 2009 12:06 pm
Hi Bill
Old problem from the wagon. I went over to my inlaws house to grab the engine and I decided to do a partial teardown. Later down the road, I am going to rebuild this one. I will probably need a new crank, or some big bearings.
PostSubject: Re: found the problem.   Tue Aug 04, 2009 5:52 pm
Dat rawght thare cood be yur prablem!
Bummer.
Mobil 1 would fix it. Wink
PostSubject: Re: found the problem.   Tue Aug 04, 2009 6:22 pm
Bummer.
I did use mobil 1
I can only think I may have gotten something lodged in the oil passage replacing the gaskets. scratch
Either way, there it is. Evil or Very Mad
found the problem.
» SAMSUNG G600 Restart done...
» possible 4l60e problem?
» Snow White is so glad she found you!!!
» two headed Arowana found ....
» I Found the Whole Attila Movie On Youtube!
