I got a 94 caprice it needs a e brake cable and the radiator fans wont kick on i just replaced the alternator and have 4 thousand dollars in receipts from the struts and brake ignition module tires 68k on it last but not least the biggest issue is a deivers side window is broken also have a lot of parts for the car middle boro junk yard has a caprice and window for $40 if they remove it 30 if you go do it 774 381 1956 call or text me
