Wheel and Tire Recommendation EmptyWed Oct 19, 2022 1:27 pm by scot
Wheel and Tire Recommendation EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Wheel and Tire Recommendation EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Wheel and Tire Recommendation EmptyFri Sep 24, 2021 9:53 am by ElKy
Wheel and Tire Recommendation EmptySun Sep 19, 2021 6:22 pm by black blur 96
Wheel and Tire Recommendation EmptySun Jun 20, 2021 11:37 am by scot
Wheel and Tire Recommendation EmptyFri Jun 11, 2021 10:41 am by scot
Wheel and Tire Recommendation EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Wheel and Tire Recommendation EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
2 posters
Chris Klein
PostSubject: Wheel and Tire Recommendation   Wheel and Tire Recommendation EmptyMon Nov 23, 2020 10:01 pm
Can someone help me figure out which tire and wheel packages to purchase for my Dad's Impala? I am hoping to steal a deal this Black Friday if ever this shop will have a sale.
scot
PostSubject: Tires   Wheel and Tire Recommendation EmptyThu Mar 11, 2021 2:33 pm
In case you have not bought tires (Nov is long ago now):
The best tire for an SS I've used, Nitto 555 G2 in 275/50-17, perfect on OEM SS 8.5".
Better than any 255/50-17 in braking, handling, highway speeds gas mileage and ride.
Taller tire does give a little away on launch. Very little.
Chris Klein likes this post
Chris Klein
PostSubject: Re: Wheel and Tire Recommendation   Wheel and Tire Recommendation EmptyMon Jun 07, 2021 11:06 pm
Better than any 255/50-17 in braking, handling, highway speeds gas mileage, and ride.
Thanks, Scott, I actually ended up buying the said tire model last year. Many of my friends have it on their car, so I decided to avail of a set, and it is definitely worth it.
scot
PostSubject: Re: Wheel and Tire Recommendation   Wheel and Tire Recommendation EmptyFri Jun 11, 2021 10:41 am
If you have an OEM 94-96 SS:
The best sway bar modification is to replace the rear 1 3/16" solid rear bar with a 1 3/8" hollow aftermarket bar or a 1 1/4" solid one. Same effect from either, far less understeer, no real added harshness to the ride. Neutral handling.
For a softer ride, and neutral handling, keep the OEM rear bar and replace the front bar with a 1 3/16" solid (FE1) bar. More body roll and better handling? Yes.
For optimal control (at the expense of that soft ride), 1 3/8" solid F+R bars.
My 94 SS has 1 1/2" solid F+R bars (long discontinued from Quickor Suspensions) which require frame braces F+R to keep from bending the frame; severe ride, amazing handling.
» Impala wheel and tire FS
» WTB: 18" truck tires or 17"+ wheel/tire package
» Backspacing/staggered wheel/tire/calibration questions
» Wheel/tire width/backspacing / offset visual calculator
