95 9C1 - REALLY CHEAP PARTS EmptyWed Oct 19, 2022 1:27 pm by scot
95 9C1 - REALLY CHEAP PARTS EmptyTue Oct 18, 2022 8:58 pm by silverfox103
95 9C1 - REALLY CHEAP PARTS EmptyTue Sep 28, 2021 11:01 pm by silverfox103
95 9C1 - REALLY CHEAP PARTS EmptyFri Sep 24, 2021 9:53 am by ElKy
95 9C1 - REALLY CHEAP PARTS EmptySun Sep 19, 2021 6:22 pm by black blur 96
95 9C1 - REALLY CHEAP PARTS EmptySun Jun 20, 2021 11:37 am by scot
95 9C1 - REALLY CHEAP PARTS EmptyFri Jun 11, 2021 10:41 am by scot
95 9C1 - REALLY CHEAP PARTS EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
95 9C1 - REALLY CHEAP PARTS EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
8 posters
PostSubject: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptyFri Jul 31, 2009 1:10 pm
Hey guys, I picked up the 9C1 from BottleBird (No motor/trans), I am buying it simply for the frame, but I would like to make my money back on buying it and picking it up.
Rear end: $150
Everything else: No more than $25! Seats, door panels, Hood, trunk, fenders, you name it and it's $25 or less! Only thing is you have to come get it.
PM me with your needs and when you can get over here.
95 9C1 - REALLY CHEAP PARTS 959c1001
95 9C1 - REALLY CHEAP PARTS 959c1004
95 9C1 - REALLY CHEAP PARTS 959c1002
95 9C1 - REALLY CHEAP PARTS 959c1007
95 9C1 - REALLY CHEAP PARTS 959c1005
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptyFri Jul 31, 2009 1:45 pm
If I had someone who could put it in for me I'd buy the rear in a second. Where are you located again cause I can use some little things.
PostSubject: 95 9c1- really cheap parts   95 9C1 - REALLY CHEAP PARTS EmptyFri Jul 31, 2009 4:11 pm
give bill fisher a call. they did my t56 install. cheap. and did a excellent job. ive no complaints. the shop number is 781-352-4710. there in norwood mass.
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptyFri Jul 31, 2009 4:35 pm
Thanks for the reccomendation Ron.
Yea Brad, we could definately do it for you here.
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptyFri Jul 31, 2009 5:28 pm
How is the body shell itself? Looks solid from the pics.
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptyFri Jul 31, 2009 5:49 pm
I'm on a fixed income which doesn't allow me much "play" money. Otherwise you guys would be doing my suspension work for me too. I'd need to get the rear + the driveshaft and then have it installed all for under $250 to even consider it right now. After I pay off my suspension parts I'll have a chance to save up for shop labor.
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptyFri Jul 31, 2009 5:56 pm
how is the drivers door panel ?
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptyFri Jul 31, 2009 7:41 pm
I am in Walpole, NH 03608.
Surprisingly good shape. the 1/4s have the typical rot at the very bottom, but better than most I have seen, there are dings here and there, but all in all it is pretty solid...
I seam to recall it being decent, I will be at my property tomorrow, where the car is located, and I will check it out and PM you.
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptySat Aug 01, 2009 6:34 am
I bet if we did a mod day, we could get that rear installed in no time flat!
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptySat Aug 01, 2009 8:02 am
gesus Doug, ur gaining on me. Laughing
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptySat Aug 01, 2009 8:29 am
I will give you $25 for the body shell. Razz
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptySat Aug 01, 2009 2:02 pm
I'm waiting on my mechanic to get back to me with a quote to pickup and install the rear in my car. I'll let you know for sure when I hear back from him.
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptySat Aug 01, 2009 5:51 pm
After I sell what everyone else wants, I'll happily sell it to you for $25 Smile
Sounds good, let me know!
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptySat Aug 01, 2009 6:19 pm
My first mechanic fell through because there's no room to work after he buys a shell off some guy for $25 Laughing
I'll see what it runs to have Fishah do the install for me and go from there.
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptySat Aug 01, 2009 9:18 pm
I'm going to need a price on the rear plus the driveshaft which I think I'll need too for this swap. If there is anything else involved in going from the 7 to 8.5 rear then I'll need that too. This may turn out very well for everyone since my transporter needs to hit you up for parts anyway Very Happy
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptySat Aug 01, 2009 11:27 pm
pretty much it . if its a disc rear u may want to redo the brakes n everthing to make sure it all work correctly, can get away with the exsisting porportioning valve and m/b cyl, but may not hurt to have it from the donner car
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptySun Aug 02, 2009 1:00 am
F-it, I've had a rough day, I'll try to brighten someone else's...Master cylinder and drive shaft will come with the rear as long as I don't have to pull it Wink
PostSubject: 95c1 really cheap parts   95 9C1 - REALLY CHEAP PARTS EmptySun Aug 02, 2009 8:36 am
when i had my eaton posi put in. i had bought a complete set of bearings. the posi took some different ones. so ive got some bearings you might need. maybe the most of them. if you want them lmk. help you save some money. im going down to my storage today. and get a bunch of parts for billymac. ill pick these up and take some pics of them. unless your just going to install the complete rear end. well ive got them if you need them.
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptySun Aug 02, 2009 11:51 am
Brad,
I think M/C and Prop valve are the same.....?
All you need is the Axle and Driveshaft.
Granted, it would be a good idea to replace pads, rotors, (maybe calipers) as well as U-Joints and maybe brake lines.
PostSubject: 95 9c1- really cheap parts   95 9C1 - REALLY CHEAP PARTS EmptySun Aug 02, 2009 1:18 pm
i dont even know what these parts are going on to. but if you have drum brakes on the rear now. youve got to change the brake lines. where they hook up to calipers for the rear disk. at least i did. when i put mine on. i went with stainless braided lines. and i still have the line that goes up top of the axle to the junction near body. they didnt change it. kinda upset me. but when you have your axle out would be a good time to install the one i have. lmk if you want it ok?
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptySun Aug 02, 2009 2:54 pm
remember too that the brake line has a european bubble end at the caliper and a sae on the other, took mine to a/zone and bent it up and reflared the sae end using the old ones as a template, then painted the with that por 15 stuff,
iceman i can understand why they didnt change that one line ... its a royal pia ,i think it took me longer to that than the swap itself.. lol
95 9C1 - REALLY CHEAP PARTS Hpim0168
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptySun Aug 02, 2009 3:13 pm
Checked out the door panel, it is pretty well cracked in the middle, sorry!
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptySun Aug 02, 2009 4:03 pm
Thanks anyways Doug
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptySun Aug 02, 2009 4:12 pm
Ron there is a simple trick to doing the rear line, they just have to pull the clip off and pull the line
thru the frame then put the flare wrench on it
PostSubject: 95 9c1-really cheap parts.   95 9C1 - REALLY CHEAP PARTS EmptySun Aug 02, 2009 4:19 pm
no i didnt know that about the brake line. i bought my complete rear disk set up from e-bay. came with every thing. then i have my friend who owns meineke muffler install my parts. i do know that por coating is about the best. and not only does he install my parts he gives me a break on the labor. and if im a little short he lets me charge it. thats why i keep going back. they put in my eaton posi with the 4.11 gears. perfect no whine or any thing. but he couldnt put that tranny in for what bill did it for. now that rear set up you posted the pic of. is that in yours now? that looked good. all i did to mine. was put on a jegs bearing support cover. cleaned it up a little bit. and sprayed it with 3m under coating. maybe when i have my lower control arms put on. ill do a better job. Very Happy
PostSubject: 95 9c1- real cheap parts   95 9C1 - REALLY CHEAP PARTS EmptySun Aug 02, 2009 4:24 pm
you know what a simple trick to me is? pay some one to do it. lol i was under the dash the other day. im still lame. to many years of driving got me out of shape and lazy i guess. but i will try to remember that. see you at bills?
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptySun Aug 02, 2009 4:34 pm
I'm too cheap to pay someone to do something I can do. I'll see you there if he needs help Ron.
Bobby
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptySun Aug 02, 2009 8:00 pm
The master is the same as what I have. I'll need the rear-end, driveshaft, and e-brake cable. I'll get new u joints from one of the part places unless Fishah wants to get them through whoever they go through at work. The new pads and lines will have to wait till later. I'm already over budget if I go through with this plan. I'll have a deffinite quote on Monday or Tuesday and let everyone know from there.
I'll also start spraying everything down with pb blaster in advance so hopefully everything comes apart easy once the car gets to the shop.
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptySun Aug 02, 2009 8:16 pm
A rearend changeout is very easy. I have done it in about two and a half on jack stands, and about an hour and a quarter or so in the air. 10 bolts, 4 driveshaft, 2 for shocks, and 4 upper and lower control arms, two brake lines, and ebrake cable.
PostSubject: Re: 95 9C1 - REALLY CHEAP PARTS   95 9C1 - REALLY CHEAP PARTS EmptySun Aug 02, 2009 11:38 pm
I need to apologize to Pooge for bastardizing his post. From now on we'll go back to making it a "parts for sale" thread.
» Cheap parts
» CHEAP PARTS!!
» Some v6 parts for cheap
» A BOATLOAD OF PARTS CHEAP!!!!!!!!!!!!!!!
» WANTED and need bab a Cheap Cheap run around car winter car
