» Looking for SEO 6J6 wiring [FOUND]
Wanted  Fisher Push Plates for 03-07 GM 1500 EmptyWed Aug 21, 2019 4:28 pm by MASShole9C1
Wanted  Fisher Push Plates for 03-07 GM 1500 EmptyThu Aug 08, 2019 9:41 am by CrashMaster
» 1984 Caprice project
Wanted  Fisher Push Plates for 03-07 GM 1500 EmptySun Jun 30, 2019 8:05 pm by Boxchevy84
» C10: Before and After
Wanted  Fisher Push Plates for 03-07 GM 1500 EmptySun Jun 02, 2019 3:01 pm by MalibuSSwagon
Wanted  Fisher Push Plates for 03-07 GM 1500 EmptySat Mar 16, 2019 8:49 am by boojum
» Mass refugee now in Pa
Wanted  Fisher Push Plates for 03-07 GM 1500 EmptyTue Jan 22, 2019 8:46 am by MASShole9C1
Wanted  Fisher Push Plates for 03-07 GM 1500 EmptyTue Jan 22, 2019 12:03 am by boojum
» 1996 DGM RMW
Wanted  Fisher Push Plates for 03-07 GM 1500 EmptyFri Jan 18, 2019 12:00 pm by Gorillabiter
August 2019
Share
PostSubject: Wanted Fisher Push Plates for 03-07 GM 1500   Wanted  Fisher Push Plates for 03-07 GM 1500 EmptyWed Jun 29, 2016 11:49 pm
I'm looking for a set of Fisher push plates for a 03-07 GM 1500. The part number is 7168.
PostSubject: Re: Wanted Fisher Push Plates for 03-07 GM 1500   Wanted  Fisher Push Plates for 03-07 GM 1500 EmptyWed Jul 20, 2016 1:30 pm
PostSubject: Re: Wanted Fisher Push Plates for 03-07 GM 1500   Wanted  Fisher Push Plates for 03-07 GM 1500 EmptySun Jul 31, 2016 8:24 pm
I have a set off a 2000 Silverado, don't know if that'll work for you
PostSubject: Re: Wanted Fisher Push Plates for 03-07 GM 1500   Wanted  Fisher Push Plates for 03-07 GM 1500 EmptyMon Aug 01, 2016 12:18 am
Fisher shows 7160 for 99 - 02. It seems that the bumpers are a bit further out on 03-07 and required a longer push plate to clear the bumper and there is a difference at the front of the frame with the welded on mounts for the bumper.
So I don't know if they would/could work with any minor mods.
PostSubject: Re: Wanted Fisher Push Plates for 03-07 GM 1500   Wanted  Fisher Push Plates for 03-07 GM 1500 EmptyWed Aug 03, 2016 8:16 am
I'm betting its for the Silverado application from 2003 and up that uses the squinty "I have to take a dump" facade.
From everything I've seen...99 to 02 truck and 03 to 06 Tahoe Suburban items are interchangeable because they kept the old nose
» Scale number plates
» Wanted: .10 Size Glow Motor
» Wanted: centers for Roadmaster wheels / front turn signal lens
» Nameplates
» Wanted cox .010
