» Roundup pics?
» Looking for exhaust part
» hello everyone
December 2018
3456789
10111213141516
17181920212223
24252627282930
31
 I Have Found the Dark Side
PostSubject: I Have Found the Dark Side   Sat May 14, 2016 2:22 pm
It's right above the cut off line from my new headlight.
PostSubject: Re: I Have Found the Dark Side   Sat May 14, 2016 8:46 pm
I need this into life.
PostSubject: Re: I Have Found the Dark Side   Sun May 15, 2016 11:27 am
Morimoto Mini?
PostSubject: Re: I Have Found the Dark Side   Mon May 16, 2016 12:20 am
From Morimoto:
mini H1 7.0 50w 5500K
9006  harness
9007/9004 male connector
retrorubber
I also used some JB weld, a couple plumbing adapters/pipe/caps, a couple headlight polishing kits, other sandpaper/discs, and a diode.
I had to modify the wiring harness with the 9007 male connector and lengthen the driver's side. This version of the H1 is a bit shorter but is still only about 2mm from the lens. I had to cut the headlight bucket a bit to get it to fit. I can post photos if I can find them. I also cut the core support a bit.
PostSubject: Re: I Have Found the Dark Side   Mon May 16, 2016 7:46 am
5 years ago I did this to ye old Honda.
Projector fit right after I trimmed the headlight bucket a bit. Also built a relay harness as the HIDs draw alot of power at startup.
PostSubject: Re: I Have Found the Dark Side   Wed May 18, 2016 8:03 pm
Pretty cool!
» My Trip to the Dark Side/Pooges
» Estalian Sun
» NaruHina story ideas
» [Casual Event] Vacation to the Dark Side (The Real Housewives of the Dark Side)
» [Relaxed] The Dark Side of the Rose
