» Mass refugee now in Pa
» 1996 DGM RMW
» Roundup pics?
» Looking for exhaust part
February 2019
 Part #?
PostSubject: Part #?   Mon Apr 25, 2016 8:19 am
Does anyone have a part number from any manufacturer for the manifold to cat flange stud and nut on a stock LT1? Also is there any trusted/go-to 3 bolt flange gaskets you can recommend? TIA
PostSubject: Re: Part #?   Mon Apr 25, 2016 9:33 am
3/8-16 on the manifold side and metric on the cat side, I forget the size. I just use 3/8-16 studs from the local hardware store. I think Dorman has an assorted pack with 3/8-16 studs in the pack.
Fel-pro has changed to the paper looking gaskets. Last time around I got a different brand from Autozone.
PostSubject: Re: Part #?   Wed Apr 27, 2016 10:15 pm
I got the numbers I was looking for and ordered them from napa.
PostSubject: Re: Part #?   Sat Apr 30, 2016 9:00 pm
Ok never mind. The napa studs that came are pretty far off, not even close.
PostSubject: Re: Part #?   Sun May 01, 2016 12:53 am
10220453 ? Maybe I was wrong about the metric/std but that's what I remembered from that other forum. Oh well 3/8-16 worked for me.
http://www.gmpartsgiant.com/parts/gm-stud-exh-10220453.html
found it...
http://www.impalassforum.com/vBulletin/22-exhaust/929993-manifold-triangle-flange-bolts-2.html
PostSubject: Re: Part #?   Sun May 01, 2016 1:51 am
I read that whole thread. I put the nut and gasket part #s into the link you provided for the stud on GMpartgiant. I wonder how different the GM gaskets will be compared to what I got from napa. Thanks a ton for the info from the way back machine!
The napa parts #s I was given are
Gaskets: FPG 60988
Stud kit: 600-1816
Part #?
» Third part of Naruto?
» [Supplement] Relics of the Crusades
» The Curse of the Black Spot
» It isn't the 1930s - Part 1
» Columns Interview Series Part IV: dye882003/ookamidesu
