From Morimoto:
mini H1 7.0 50w 5500K
9006 harness
9007/9004 male connector
retrorubber
I also used some JB weld, a couple plumbing adapters/pipe/caps, a couple headlight polishing kits, other sandpaper/discs, and a diode.
I had to modify the wiring harness with the 9007 male connector and lengthen the driver's side. This version of the H1 is a bit shorter but is still only about 2mm from the lens. I had to cut the headlight bucket a bit to get it to fit. I can post photos if I can find them. I also cut the core support a bit.
