» hello everyone
» Look familiar?
Fri Sep 14, 2018 2:01 am by mrlazuli
Thu Sep 13, 2018 1:53 am by mrlazuli
Thu Sep 13, 2018 1:49 am by mrlazuli
» Another MA newbie, but with no car yet :(
Wed Sep 12, 2018 11:48 am by MASShole9C1
» 96 black fleetwood for sale
Tue Sep 11, 2018 8:35 pm by Ironfistdog
» Set of brand new MOOG 5662 coils
Tue Sep 11, 2018 8:31 pm by Ironfistdog
September 2018
3456789
10111213141516
17181920212223
24252627282930
 stock rear specs ?
FUN-9C1
PostSubject: stock rear specs ?   Wed Feb 17, 2016 10:24 pm
I am seriously considering putting some 4.88s into my 9C1 and then maybe putting the 4.10s that are in it into my RMW. Before I buy the 4.88s I just want to make sure I remember correctly- I need gears for a 10 bolt 8.5" GM- am I good with that or are there any other specs I need to confirm?
Also- I seem to recall when I bought the 4.10s that they were from Precision Gear. Does that ring a bell? Did they change hands or go out of business? Can't find 'em anymore.
Thanks,
FUN-9C1
PostSubject: Re: stock rear specs ?   Wed Feb 17, 2016 10:27 pm
Spline? Just thought of that... 28 or 30 are possibilities IIRC?
PostSubject: Re: stock rear specs ?   Wed Feb 17, 2016 10:50 pm
8.5 10 bolt 30 spline (88 or 89+ have 30 spline)
FUN-9C1
PostSubject: Re: stock rear specs ?   Wed Feb 17, 2016 10:55 pm
Thanks man!
PostSubject: Re: stock rear specs ?   Wed Feb 17, 2016 10:58 pm
Since you mentioned spline, don't forget that the 9C1 axels are shorter than an SS or regular non 9C1 Caprice. If you for some reason wanted to order them too.
FUN-9C1
PostSubject: Re: stock rear specs ?   Fri Feb 19, 2016 11:50 pm
Thanks for the axle info,
So I asked this guy- "Hi there, are these 28 or 30 spline?"
and he replied- "That will be carrier based, not gear based. Gears will work with either."
I don't believe that to be true........ but then again I've been out of the scene for a while. Is he right?
Thanks for the help.
The 4.88 seed has been planted........ it is probably inevitable now...........
I just have to remember everything I forgot about the swap..........
PostSubject: Re: stock rear specs ?   Sat Feb 20, 2016 2:03 am
The drive shaft turns the pinion. Pinion turns the gear. Gear is bolted to the carrier. Carrier turns axels. Think about it.
PostSubject: Re: stock rear specs ?   Sat Feb 20, 2016 8:22 am
What size tire are you running? 225/75's? That engine is gonna be screaming at 65-70 mph.
PostSubject: Re: stock rear specs ?   Sat Feb 20, 2016 9:51 am
Your guy would be correct, the splines are carrier based since the axles engage the carrier, the ring gear is just bolted to the carrier.
FUN-9C1
PostSubject: Re: stock rear specs ?   Sat Feb 20, 2016 11:12 am
235/70s. Yup, about 3k @ 70. It's turned into more of a toy than a daily driver. Should be fun around town and at New England Dragway and it will keep me from speeding on the highway. Smile It's programmed to shift at 6k, and with 4.88s it would be just about to shift into 4th going through the traps.
Super un-practical, I know, but the extremist part of me just feels like it needs to be done. Smile
FUN-9C1
PostSubject: Re: stock rear specs ?   Sat Feb 20, 2016 11:14 am
I'm talking about the splines on the pinion gear. Or are they all the same? Seems to me I remember that could be either 28 or 30 also? No?
PostSubject: Re: stock rear specs ?   Sat Feb 20, 2016 1:34 pm
Splines refers to axles. Rear gears are comprised of the ring and pinion gears.
FUN-9C1
PostSubject: Re: stock rear specs ?   Sat Feb 20, 2016 2:20 pm
I guess I'm not explaining myself very well- I'm talking about the splines on the front end of the pinion gear shaft where the yoke goes on. I put the 4.10s in my 9C1 myself but that was 100,000 miles ago and I forgot most of what I learned on that project.
Thanks for the info.
PostSubject: Re: stock rear specs ?   Sat Feb 20, 2016 8:13 pm
Just to clear this up an 8.5 GM 10 bolt take the 30 spline pinion
The 7.5 GM 10 bolt takes the 27 spline pinion.
FUN-9C1
PostSubject: Re: stock rear specs ?   Sun Feb 21, 2016 8:57 pm
thank you.
stock rear specs ?
» New Member-----Returning ST-70 to stock specs.
» Stock Impala Ride Height
» FODEN REAR SPRINGS
» GN rear window mod
» roadmaster rear 8.5"?
