» Mass refugee now in Pa
» 1996 DGM RMW
» Roundup pics?
» Looking for exhaust part
February 2019
 OIL FILTERS
PostSubject: OIL FILTERS   Fri Jan 29, 2016 9:16 pm
What are people running for oil filters these days? The AC Delco filter is now PF52E, and it looks cheesy. It also states with threaded insert. What ever that means. I just want a good filter I can know won't fail.
PostSubject: Re: OIL FILTERS   Sat Jan 30, 2016 12:38 am
I just use the fram one. Dunno the part # off the top of my head tho.
PostSubject: Re: OIL FILTERS   Sat Jan 30, 2016 11:36 am
I like the white purolator classic filters. They aren't expensive and are made like the old style Delco ones. The other more expensive ones don't seem to be any better to me.
PostSubject: Re: OIL FILTERS   Sat Jan 30, 2016 1:40 pm
I have heard a lot of positive about Purolator. I may try that one. I had to replace the oring, and gasket in the filter adapter along with the cooler lines. So what better time to do a oil change, and PCV valve.
PostSubject: Re: OIL FILTERS   Sat Jan 30, 2016 2:18 pm
On occasion I look at "Bob the Oil Guy" forum.  Off of the top of my head the ones that are recommended are Wix, Purolator, NAPA Gold, and surprisingly WalMart's own brand.  I don't seem to see WalMart's brand anymore at the stores.  Hand's down the absolute worst, Fram.
PostSubject: Re: OIL FILTERS   Sat Jan 30, 2016 9:45 pm
Since I have every vehicle in the fleet running the same filter now, I buy Napa golds by the 12-pack like a garage would, without boxes... They are stupid cheap, like $3 or so, and work well.
MancheSSterJake
MancheSSterJake
PostSubject: Re: OIL FILTERS   Mon Feb 29, 2016 4:23 pm
If you want a quality filter that actually does filtering the only option is WIX. Most Napa filters are Wix filters.
I have seen independent filter research that was eye opening.
Wix was the best. Fram was one of the worst, it mostly just reduced your oil pressure.
PostSubject: Re: OIL FILTERS   Mon Feb 29, 2016 5:38 pm
You got it Steve!
demilo
PostSubject: Re: OIL FILTERS   Fri Dec 22, 2017 4:53 am
I use Purolator filter. Not expensive and works fine.
PostSubject: Re: OIL FILTERS   Fri Dec 22, 2017 7:41 am
Anything but Fram.
OIL FILTERS
» small fuel filters for 1/2A
» What to do with filter after Ick treatment?
» Under Gravel Filters??
» filters for a 4 foot tank
» Fluidized bed filters???
