| Anyone have an obd1 pcm with vats disabled that I can borrow/buy? | |
+5Ironfistdog MalibuSSwagon Pooge sdstick 8bud 9 posters |
| Subject: Anyone have an obd1 pcm with vats disabled that I can borrow/buy? Wed Oct 14, 2015 10:44 am | |
| Got my S10 project running (bout time!) but it shuts off after one second of running. The place that tuned my pcm (current performance) claims they definitely disabled the vats in my pcm, but it seems like it would have to be that since it keeps shutting off instantly and we have tried several other troubleshooting possibilities with no luck. Does anyone have an obd1 pcm thhas the vats disabled that I can plug in just to see if the truck will stay running? Thanks. | |
| Subject: Re: Anyone have an obd1 pcm with vats disabled that I can borrow/buy? Wed Oct 14, 2015 11:34 am | |
| Dont have a pcm but its not an oil pressure switch thing right? | |
| Subject: Re: Anyone have an obd1 pcm with vats disabled that I can borrow/buy? Wed Oct 14, 2015 4:51 pm | |
| Yup not the issue, thanks for the input, Steve. Open to any and all suggestions, but this seems the most likely possibility at this point. PCM anyone? Or the ability to plug mine in and check if the vats is indeed off? | |
| Subject: Re: Anyone have an obd1 pcm with vats disabled that I can borrow/buy? Fri Oct 16, 2015 8:57 am | |
| Subject: Re: Anyone have an obd1 pcm with vats disabled that I can borrow/buy? Fri Oct 16, 2015 12:13 pm | |
| To flash the PCM, you need the WinFlash program from Tunercats, which has a free 30 day trial | |
| Subject: Re: Anyone have an obd1 pcm with vats disabled that I can borrow/buy? Fri Oct 16, 2015 6:59 pm | |
| What fuel pump are you running in the truck?
Did you check for bad ICM already? | |
| Subject: Re: Anyone have an obd1 pcm with vats disabled that I can borrow/buy? Sun Oct 18, 2015 9:02 am | |
| Def sounds like VATS. Just went through this with 94 9C1. I believe my tech eliminated all the VATS related components, PLUGGED the PCM in from PCM forless and she's been firing true since. Not sure when I'll be down that way again but could make it happen. If I do I'll PM you. | |
| Subject: Re: Anyone have an obd1 pcm with vats disabled that I can borrow/buy? Tue Oct 20, 2015 1:18 pm | |
| Okay, so I found a stock pcm from a 95 impala in my pile of parts. So I have that. Next step is to get the vats turned off so I can plug it min and at least see if the truck will stay running. I put a fuel pump from an impala in it, so that should be ok. Have not checked the computer for the truck...that's my issue here. The only vats related component I would have in this project is the pcm. Anyone local that you guys can recommend that I can bring the spare pcm to and have them eliminate the vats? | |
YachtDriver
| Subject: Re: Anyone have an obd1 pcm with vats disabled that I can borrow/buy? Tue Oct 20, 2015 3:42 pm | |
| Instead of eliminating it you might be able to use one of these to simulate the signal.
http://www.ebay.com/itm/GM-VATS-or-PASSkey-II-Bypass-Module-For-LS1-and-LT1-/281813159375?hash=item419d5f8dcf:g:sysAAOSwN81WEYiu&vxp=mtr ebay link.
might be less $ than paying for a tune if the tune is already ok on the PCM.
| Subject: Re: Anyone have an obd1 pcm with vats disabled that I can borrow/buy? Tue Oct 20, 2015 4:47 pm | |
| - 8bud wrote:
- Okay, so I found a stock pcm from a 95 impala in my pile of parts. So I have that. Next step is to get the vats turned off so I can plug it min and at least see if the truck will stay running. I put a fuel pump from an impala in it, so that should be ok. Have not checked the computer for the truck...that's my issue here. The only vats related component I would have in this project is the pcm. Anyone local that you guys can recommend that I can bring the spare pcm to and have them eliminate the vats?
I don't know of anyone local, most tuners have moved on to the LSx side of things. http://lt1swap.com/programming.htm | |
| Subject: Re: Anyone have an obd1 pcm with vats disabled that I can borrow/buy? Thu Oct 22, 2015 11:24 pm | |
| I know a local guy. You would have bring the PCM to him. Check one or reprogram the other, your choice. | |
| Subject: Re: Anyone have an obd1 pcm with vats disabled that I can borrow/buy? Fri Oct 23, 2015 9:32 am | |
| Thanks, Guys. I may send it out to the guy Eric suggested, but I might get ahold of you Jim to have your guy do it. When I get some spare timeI'll figure it out. I have to hurry up, I promised Crovo he could drive it. Of course that was like three years ago now | |
| Subject: Re: Anyone have an obd1 pcm with vats disabled that I can borrow/buy? Sat Oct 24, 2015 12:44 pm | |
| I found a couple PCMs yesterday while unsuccessfully searching for my inch & a half open end wrench. Shoot me a text. | |
| Subject: Re: Anyone have an obd1 pcm with vats disabled that I can borrow/buy? | |
