» Mass refugee now in Pa
» 1996 DGM RMW
» Roundup pics?
» Looking for exhaust part
March 2019
 MA 9C1
PostSubject: MA 9C1   Sun Apr 26, 2015 8:17 pm
About 2 weeks ago at my state inspection it was pointed out to me that the water pump was leaking. About a week later it got much worse. I also sometimes had difficulty starting the car. I put a used opti jn somewhere around 60k miles ago so I thought it might be time for a new one. This weekend it got a new water pump, opti, oil change, new plugs, lube, and a new used ignition coil. I could not find a 9C1 coil so I had to use one from an Impala.
That is all.
PostSubject: Re: MA 9C1   Sun Apr 26, 2015 8:39 pm
Cool story Jim. What's an opti, and what is a 9c1 coil? Wink
PostSubject: Re: MA 9C1   Sun Apr 26, 2015 10:15 pm
Which, MSP 9C1 tho? Wink
Should've just tapped the weep hole with a zerk (sp?) fitting, drilled out the fitting, and stuck a hose on it. Let it leak all you want. Just not on the opti.
24x conversion time?
PostSubject: Re: MA 9C1   Sun Apr 26, 2015 10:43 pm
A 9C1 ignition coil works with the cop chip to give you the best performance gains. An opti is a general term for the components that replaced the older points ignition system. GM's opti system costs up to 25 times the cost of the old points ignition system but don't dwell on the costs, just think of it as progress.
PostSubject: Re: MA 9C1   Sun Apr 26, 2015 10:49 pm
The same car that I had at Chris'. This pump was actually leaking at the front cover.
I think LS7s have a 58x CPS.
MancheSSterJake
MancheSSterJake
PostSubject: Re: MA 9C1   Mon Apr 27, 2015 10:48 am
I have found that once a water pump on the LT1 starts to leak it deteriorates very rapidly.  The rear bearing on the water pump takes a beating.  One of the things that accelerates the demise is lack of use.  For those of us who park their cars for the winter you will see your water pump life drop in half.
PostSubject: Re: MA 9C1   Mon Apr 27, 2015 12:07 pm
I have 3 LT1 cars, that are parked in the winter and probably between all of them they don't get driven 1500 miles a year. They all drip.
PostSubject: Re: MA 9C1   Mon Apr 27, 2015 12:35 pm
zerk fitting in the top of the opti, why am I always the last to know this sh!t
PostSubject: Re: MA 9C1   Mon Apr 27, 2015 9:30 pm
Doesnt matter WHEN you know...you dont have time to do it anyway
Find time for that ^^^ tho...noticable change in performance.. Arrow
PostSubject: Re: MA 9C1   Mon Apr 27, 2015 9:34 pm
Surprised face palm
Have you ever thought about doing standup?
PostSubject: Re: MA 9C1   Mon Apr 27, 2015 9:50 pm
Blah blah blah.
PostSubject: Re: MA 9C1   Tue Apr 28, 2015 9:54 pm
Surprised face palm
I would need a better angle. At least here we have two or three carburetor guys that might get my jokes. Ultimately it's a matter of timing and the being in the right place. Hopefully I have made these points clear, it's not my intent to spark a debate of the old and new designs.
oh and before I forget, if you have '93 or '94 F-body you put a hole in the opti itself but that's a topic for another forum.
PostSubject: Re: MA 9C1   Thu Apr 30, 2015 11:47 pm
Surprised face palm
MA 9C1
