Subject: Building Heads/Cam LT1 Thu Feb 26, 2015 10:16 pm
I've been building a motor for a guy down here in Orlando. He originally wanted to do a cam.. then heads... but with 160k+ I didn't want to trust the bottom end. He brought the car here I yanked the motor and ended up rebuilding it... on a budget. Stock 350 bottom end reused rotating assembly. Basic machine work light hone, crank polish, new bearings and rings. Motor was in decent shape. Rod bearings were toast. It ran very well and made no noises before.
Advanced Induction 190cc heads, CC305 cam.
Mock up. top end not mounted just sitting on the block, heads were on backwards.
Assembly will be completed this weekend and maybe I'll drop it in the car.
Subject: Re: Building Heads/Cam LT1 Fri Feb 27, 2015 6:19 am
Looks great. SOooo nice to start fresh isnt it?
Over the valve cover wires can get tricky....depending on whats taking the exhaust outta there
Subject: Re: Building Heads/Cam LT1 Fri Feb 27, 2015 7:26 am
There are going to be longtube after burners. I have a 30ft roll of wire and my own ends so I will cut them so there is plenty of space.
Subject: Re: Building Heads/Cam LT1 Fri Feb 27, 2015 10:11 am
I can take a pic of Matts car if you want to know what you'll be dealing with for room As I remember #5 is tough....I'm sure you'll be fine
You still looking for the seatbelt? REALLY sorry I havent been able to do that simple task I'll tell you my tale of woe someday when the dust settles
Subject: Re: Building Heads/Cam LT1 Fri Feb 27, 2015 4:25 pm
Excellent! That cam is pretty popular, I see. I plan to use the LT1 out of my rms for something. You've got me nervous about not opening up the engine and inspecting the inside of it.
Subject: Re: Building Heads/Cam LT1 Mon Mar 02, 2015 6:14 pm
Brian if the motor is working and you don't plan on more HP then leave it alone.
Painted a few parts to make the motor look nice.
You can see at the bottom of the water pump cover, one of the tabs was broken off. I filed it away and I think it looks better without it.
Might try to drop it in tonight. I need to measure pushrod length and prime the oil pump before installing the intake.
Subject: Re: Building Heads/Cam LT1 Mon Mar 02, 2015 7:13 pm
Subject: Re: Building Heads/Cam LT1 Mon Mar 02, 2015 7:51 pm
Sweet! That's pretty close to my motor. I have the CC306 and similar heads in a stock bottom-end 350. And it put down 340 to the wheels through a t56. That's over 400 at the flywheel. You should see similar numbers with a good tune.
Good stuff.
Subject: Re: Building Heads/Cam LT1 Mon Mar 09, 2015 2:06 am
aaaand its in. Still have to bolt up trans and connect wiring. Waiting on computer, 30lb injectors and correct length pushrods changed for proper valve train geometry.
Subject: Re: Building Heads/Cam LT1 Mon Mar 09, 2015 2:39 am
How much more length did you need on the push rods?
Subject: Re: Building Heads/Cam LT1 Mon Mar 09, 2015 11:36 pm
Stock length is 7.2 I needed 7.1. Every motor will be different after being machined. Heads were machined also. So I lost height.
Subject: Re: Building Heads/Cam LT1 Wed Mar 11, 2015 2:53 pm
Pretty!
Subject: Re: Building Heads/Cam LT1 Mon Apr 06, 2015 12:20 am
Car is up and running. Built transmission and converter are going in it today.
Here is the car in Daytona last weekend, me behind the wheel.
Hope the owner was the guy holding the camera..... If I had someone doing work to my car and found them beating the snot out of it in the street I'd be scraping prostate off my steel toed boots
Subject: Re: Building Heads/Cam LT1 Tue Apr 07, 2015 12:25 am
Unfortunately he left this bbody event earlier in the night and was not filming but he did see the video and loved it.
