» Mass refugee now in Pa
» 1996 DGM RMW
» Roundup pics?
» Looking for exhaust part
March 2019
 OBD2 connector replacement?????????????
PostSubject: OBD2 connector replacement?????????????    Tue Nov 11, 2014 7:43 pm
So kinda off topic. My new to me Jeep has a damaged OBD2 connector. One wire is broken, and all the other terminals are so corroded, and damaged. Is there a pig tail replacement for OBD2 ports under the dash? I can't find anything anywere on line.
Thanks.
PostSubject: Re: OBD2 connector replacement?????????????    Tue Nov 11, 2014 7:48 pm
Thanks.
I'd imagine it'd have to be a cut and splice (or solder) from a donor car. I've never heard of these needing to be replaced.
It's a Jeep thing. I don't understand.
PostSubject: Re: OBD2 connector replacement?????????????    Tue Nov 11, 2014 7:52 pm
Thanks.
Yes it is a jeep thing. I would say someone got over zelus with the whole "fording water" thing. Everything works correctly, just the connector is too damaged to use.
PostSubject: Re: OBD2 connector replacement?????????????    Tue Nov 11, 2014 7:53 pm
Be careful replacing, check with the state inspection agency on the right way to do it. I fail anything that isn't even in the right spot. You never know what car is watching you.
PostSubject: Re: OBD2 connector replacement?????????????    Tue Nov 11, 2014 8:54 pm
I am just needing to replace the connector with another one so it will work correctly. The connector itself is the same for all cars. Some have additional wires, but the connector is the same. With everything availible in pigtail form, I would figure this be a given since at least once a year it is pluged into, and can get damaged if pulled wrong.
PostSubject: Re: OBD2 connector replacement?????????????    Tue Nov 11, 2014 9:54 pm
Billy, the best and simplest way to do it is get the terminal tool or use a straight pick tool, remove one terminal at a time into the new connector. Am I oversimplifying this? Is there more to it? You mentioned a broken wire? Any dealer will have that terminal new for the wire to be crimped and to go into the DLC. You may or may not need the special crimp tool for said terminal.
PostSubject: Re: OBD2 connector replacement?????????????    Tue Nov 11, 2014 11:21 pm
I'd just grab another connector and pigtail from the junkyard, depin terminals and clean them with contact cleaner, solder and heat shrink repair the damaged wire, and pin on new connector. Simple.
PostSubject: Re: OBD2 connector replacement?????????????    Wed Nov 12, 2014 12:00 am
Soooo basically what I said.
PostSubject: Re: OBD2 connector replacement?????????????    Wed Nov 12, 2014 5:13 am
Like I said, I was hoping someone knew of a replacement pig tail. So off to the Junk yard I go.
Thanks guys.
PostSubject: Re: OBD2 connector replacement?????????????    Wed Nov 12, 2014 10:06 am
Rockauto has one listed, universal replacement. For the $40 they want grab one at the junkyard
YachtDriver
YachtDriver
PostSubject: Re: OBD2 connector replacement?????????????    Wed Nov 12, 2014 10:13 am
You can buy just the shell for about $6
obd2calbles shell
PostSubject: Re: OBD2 connector replacement?????????????    Wed Nov 12, 2014 10:34 am
Boneyahd, kehd. Like you even had to ask, guy. Wink
PostSubject: Re: OBD2 connector replacement?????????????    Wed Nov 12, 2014 2:11 pm
LOL. If you want to hide the repair from picky inspection techs, just splice the damaged wire about 6-8 inches up and wrap it into the harness. Arrow
PostSubject: Re: OBD2 connector replacement?????????????    Fri Nov 14, 2014 3:48 pm
We have a winnah. Didn't even charge me for it. I went to Lamberts in Rochester, and the guy from Car World who takes your buck to get in now works there. Pretty cool guy.
PostSubject: Re: OBD2 connector replacement?????????????    Fri Nov 14, 2014 10:46 pm
MalibuSSwagon wrote:
LOL. If you want to hide the repair from picky inspection techs 84twodoor, just splice the damaged wire about 6-8 inches up and wrap it into the harness. Arrow
Fixt
PostSubject: Re: OBD2 connector replacement?????????????    Fri Nov 14, 2014 11:08 pm
Fixt
LOL
Hey kehd. You eva splice yo hahness? Cuz if you did, I gots to give you a reject sticka. Gets ya hahness fixed kehd.
PostSubject: Re: OBD2 connector replacement?????????????    Sat Nov 15, 2014 1:37 am
Fixt
LOL
Was just friendly advice! It's good advice though....srsly bruh
» Schurter IEC noise reduction power connector
» ALPS volume control replacement on PAS3
» waterpump replacement
» Where to get this led connector?
» Bowl replacement
