» Mass refugee now in Pa
» 1996 DGM RMW
» Roundup pics?
» Looking for exhaust part
February 2019
 Starter FAIL.....
PostSubject: Starter FAIL.....   Sun Nov 09, 2014 9:36 pm
Don't like seeing her like this No No No
PostSubject: Re: Starter FAIL.....   Mon Nov 10, 2014 6:24 am
Doh. BTDT.
If you'da had a t56, you coulda stared it!
PostSubject: Re: Starter FAIL.....   Mon Nov 10, 2014 7:08 am
Mine to, can't move the Danm thing
PostSubject: Re: Starter FAIL.....   Mon Nov 10, 2014 1:14 pm
Did the solenoid separate?
I hate starter issues...put the corvette one in...(ironic isnt it?)
PostSubject: Re: Starter FAIL.....   Mon Nov 10, 2014 2:48 pm
I beat the shit out of mine Sunday with a 4ft prybar and hammer.
PostSubject: Re: Starter FAIL.....   Mon Nov 10, 2014 2:51 pm
I think you may have found your problem?
PostSubject: Re: Starter FAIL.....   Mon Nov 10, 2014 3:03 pm
Two bolts and it comes right out.
PostSubject: Re: Starter FAIL.....   Mon Nov 10, 2014 3:11 pm
Probably
When it's in between a building and my conex box it's hard to pull it Tom.
PostSubject: Re: Starter FAIL.....   Mon Nov 10, 2014 5:23 pm
Just as I thought....went out to the garage this morning and the damn thing started right up Surprised Surprised
PostSubject: Re: Starter FAIL.....   Mon Nov 10, 2014 5:24 pm
Auto Zone, 94 LT1 Vette $120-125 all done.
PostSubject: Re: Starter FAIL.....   Mon Nov 10, 2014 5:26 pm
It just clicks once and the "check gauge" light comes on. I had trouble with it a couple years back, cleaned it , replaced a wire and its been good until now.
PostSubject: Re: Starter FAIL.....   Mon Nov 10, 2014 6:42 pm
It's on it's way out replace it now. I got mine at Advanced auto. Told them it was for a 95 Corvette. They gave me a rebuilt vet starter. Smaller, and lighter than a B-body starter, and it sounds really cool too.
PostSubject: Re: Starter FAIL.....   Mon Nov 10, 2014 8:49 pm
Would this Corvette starter work on a TBI engine? My starter is getting worse, sounds like a grinder rather than a starter sometimes.
PostSubject: Re: Starter FAIL.....   Mon Nov 10, 2014 9:07 pm
Good question. I think it should. I am not sure if there is a differnce in flex plate diameter between the TBI and LT1. They should be the same. If they have the same amount of teeth, I woud say yes.
PostSubject: Re: Starter FAIL.....   Mon Nov 10, 2014 9:46 pm
Well, Rockauto says a flexplate for a 1992 OCC also fits a 91-96 Roadmaster. Hooray time to raid Jessie's change jar.
PostSubject: Re: Starter FAIL.....   Mon Nov 10, 2014 10:23 pm
I once put a '91 TBI starter on a LT1 when I couldn't' find the change jar.
You might have to stretch the battery cable a bit. On the LT1s just loosen the cable clamp on the frame rail is usually enough.
Be sure to leave enough money for the "LS1" Camaro project. Very Happy
PostSubject: Re: Starter FAIL.....   Sun Nov 23, 2014 3:41 pm
OMG, I should have put a Corvette starter in it years ago Surprised it starts up so much better now. And while I was under there I put a thermal insulation sleeve on the starter wire cause it runs so close to the headers, hopefully eliminating a future issue. I'm learnin
PostSubject: Re: Starter FAIL.....   Sun Nov 23, 2014 5:05 pm
cloud 9 wrote:
OMG, I should have put a Corvette starter in it years ago Surprised ....
Next best thing to a vet. Cool
PostSubject: Re: Starter FAIL.....   Sun Nov 23, 2014 7:37 pm
I have 2, very nice!
PostSubject: Re: Starter FAIL.....   Sun Nov 23, 2014 10:16 pm
I'm putting one in the OCC next spring when it comes out of my garage. My starter drive sticks more often than not now. No
Starter FAIL.....
» Let Yukino Kikukawa fix your EPIC FAIL! [Game]
» New 40K Starter Set
» The Starter Kits are coming...
» Another new starter
» TD .010 snap starter tip
