 Dinky Parts Needed
Bull
PostSubject: Dinky Parts Needed   Fri Jul 11, 2014 10:44 pm
I could use a driver's side window switch for my '95 RMW. I know aftermarket are available, but I'd prefer a functioning original.
I could also use a chrome lock rod post, or whatever they might be called, for the lock on the tailgate. You know, the part you pull up on or push down on to activate the lock.
And, if anyone happens to have spare end pieces for the wood grain trim, I need two I think. I can give you the part numbers if you have a stash.
Like I said, dinky stuff!
Thanks for your time.
PostSubject: Re: Dinky Parts Needed   Sat Jul 12, 2014 8:06 am
Pm returned.
I have a drivers switch from the 96 caddy which I think is the exact same switch as a RM. I will also look in my totes of parts for anything I may have stripped from the Rmw's I owned.
I'm sure I have a ton of the lock push/pull covers too.
Dinky Parts Needed
