So after owning this thing for 2+ years now, I had an occasion to use my wipers for the first time a couple weeks ago. And to my disappointment they would not shut off until I turned the ignition off and back on again, then the wipers would park.
The FSM only lists one cure for that- replace the switch. Although I don't think the FSM has ever let me down, my gut tells me (or maybe it's really wishful thinking) that if the switch was bad, they would NEVER shut off. Plus IIRC the FSM lists the symtom only as "wipers will not shut off", and that is not entirely my case. They will shut off, I just have to turn the key off then on again. The fact that they will park and shut off after turning the key off and then on again makes me think it may be another issue.
What do you guys think?
