18 - power steering control module, heated seats control
20- electric actuator, vacuum & electric solenoid, heater & A/C control, instrument cluster,DRL
44- heated power mirror
under hood
3- secondary air pump relay, under hood lamp
on 95 just unplug air pump leave fuse & relay in.
F - A/C Comp, yes if you don't want air
if you look inside the fuse panal sometimes there will only be 1 terminal for the fuse in the slot, that one does not need a fuse
