TahoeTom212
Posts : 9 Join date : 2009-05-21 Age : 38 Location : Keene, NH
| Subject: Used heads, cam and many more new and properly used parts. Thu Jan 02, 2014 11:21 pm | |
| For Sale $500.00 OBRO - Pair of cast iron LT1 heads, hand ported, polished and gasket matched by myself many years ago. Has stock sized Manley Stainless Steel valves, Comp Cam Dual valve springs w/ a third damper spring, Comp Cams Chromoly retainers and locks. Made 313 RWHP with the cam advertised below on a Stroked/stock bore 377c.i. LT1. The heads were removed to be replaced with a bigger heads and cam package. I do believe the valves were floating as a couple of the valve spring shims have worked there way out from under the valve springs. Resetting spring height would be recommended.
$150.00 obro - Comp Cams Custom Grind Roller Cam - Small base circle cam for LT1 stroker applications. Have the original cam card. I believe it has the long dowel pin for the optispark, was used in a 1996 car/block. Made 313 RWHP with the heads advertised above on a stroked/stock bore 377c.i. LT1. Was removed to be replaced with a bigger head and cam package. Grind # LT1 3314S / 3315S HR112.0 Lift .502 in/ .510 ex with 1.5 RR's or .535 in / .544 ex with 1.6 RR's duration @ .050 intake 224 / exhaust 230
$100.00 obro - 94-96 B and D body transmission crossmember $50.00 obro - 1996 4L60E valve body - purchased off ebay a while back when my transmission builder thought I might need a new valve body, figured out the problem before ever installing this valve body. $10.00 obro - new Pair of B and D body moog swaybar endlinks K5252 $50.00 obro - new Pair of D body moog HD lower balljoints for HD suspension FE7 K6141 $5.00 obro - new pair of B and D body front wheel bearing seals National 4739 $5.00 obro - new pair of national oil seals 6815 - the part # crosses over to ford vehicles, I don't know why I have these. $20.00 obro - 8x new NGK TR5 2238 V-Power spark plugs $20.00 obro - 2x new lower rear shock mounting studs $20.00 obro - 2x new custom shock mounting studs $5.00 obro - new B + D body pinion oil seal national 2043 $150.00 obro - new LT4 Hot Cam Valve springs, caps, and keepers $40.00 obro - new 2 weld on upper shock mounts $25.00 obro - used MSD Blaster coil, single wire, used on a 1996. $50.00 obro - 8x used factory LT1 fuel injectors $25.00 obro - new 4l60e rubber transmission mount $40.00 obro - stock LT1 throttle body for rebuild or porting $100.00 obro - used vented optispark distributor with MSD cap and rotor 30k on cap and rotor, used on a 1996 $20.00 obro -2x pair new B + D body front lower control arm bushings Moog 6109 $40.00 obro - new foglight kit - 2 foglights, wiring, switches. $80.00 obro - used factory 96 fleetwood 8.5" 2.98 ring, pinion and open carrier $125.00 obro - used factory auburn posi unit/carrier GM 8.5 $40.00 obro - new pair napa/skf GM 8.5" carrier bearings
All used parts were either replaced for an upgrade or replaced in an effort to remedy a problem, with no such luck. All used parts were working perfectly when removed.
Please ask any questions, and make offers. Everything is taking valuable garage space. Please text only 603-499-6017, I have many pictures on my phone ready to be sent to whoever wants them.
