February 2018
 Roadmaster 8.5 Rear 2.93
PostSubject: Roadmaster 8.5 Rear 2.93   Fri Nov 29, 2013 3:35 pm
I have a complete Roadmaster rear end with 2.93 rear gears.
8.5" Housing
It was wire-wheeled and painted semi gloss black. Has the larger drums and all new wheel studs.
150.00
Good for someone looking to build a solid piece on the ground.
PostSubject: Re: Roadmaster 8.5 Rear 2.93   Fri Nov 29, 2013 3:53 pm
Is that from a sedan or wagon? How many miles on it?
thanks
PostSubject: Re: Roadmaster 8.5 Rear 2.93   Fri Nov 29, 2013 4:14 pm
thanks
Sedan and No Clue. All I know is the Posi is tight and it doesn't make noise.
» roadmaster rear 8.5"?
» Rear end Gear ratio's?
» Two MINT 95/96 Roadmaster Wagons locally.
» PARTING OUT 1994 roadmaster wagon ADRIATIC BLUE
» Caprice or Impala Rear End
