» Roundup pics?
» Looking for exhaust part
» hello everyone
December 2018
3456789
10111213141516
17181920212223
24252627282930
31
 weird things going on with my roadmaster
bigbluey88
PostSubject: weird things going on with my roadmaster    Wed Nov 27, 2013 9:46 pm
First the car radio dies but all of the lights for the radio go on when the cars on and off when the cars off, second the gate ajar light stays on and when its off a light magically goes on in the back where the tailgate is try shutting it off it doesn't go off unscrewed one of the light bulbs so that hopefully it won't happen again. Along with that when I have my blinker on whether its left or right the seat belt dude will show up then fade repetitively until you turn your blinker off. I'm so puzzled as to why this is going on and how the heck to stop it.
PostSubject: Re: weird things going on with my roadmaster    Wed Nov 27, 2013 10:44 pm
Sounds like a short affecting multiple circuits. My 92 Olds did weird stuff like that, but with different circuits. I took the dash off, couldn't find anything wrong and put it back together. The problem went away after that. Start looking around under the dash for pinched wires are some hacked up wiring mods.
PostSubject: Re: weird things going on with my roadmaster    Thu Nov 28, 2013 8:04 am
The gate ajar and rear cargo light issue sounds like a loose sensor connection in the bottom of the tailgate. I had that same problem on the '92 I had. Easy fix there. The seatbelt light Definitely sounds like a wiring problem. Anything aftermarket added to the car? Check the engine to firewall ground cable FIRST.
bigbluey88
PostSubject: Re: weird things going on with my roadmaster    Sun Dec 01, 2013 12:28 pm
Stereo works well fuse number 2 was blown put a CD player in it anyways wife went to use lighter fuse number 2 blown again setreo shut off and same problems starting happening put another fuse in dont want to touch lighter again puzzled as to what could be causing it to blow
PostSubject: Re: weird things going on with my roadmaster    Sun Dec 01, 2013 12:46 pm
First check to make sure nothing is in the socket on the bottom (dimes, pennies, etc)
Then I'd look at the two wires on the back of the lighter itself. It shares a circuit with the radio and I think the dome light.
Check for shorts, pinched or broken wires.
» Weird Things
» Real weird issues with 94 LT1 Roadmaster sedan
» WTB: 95 roadmaster wagon grille
» Wanted: centers for Roadmaster wheels / front turn signal lens
BADASS of New England :: 91-96 B & D-body tech :: Wagon section-
