» Mass refugee now in Pa
» 1996 DGM RMW
» Roundup pics?
» Looking for exhaust part
March 2019
 Rattle from around driver's rear wheel
PostSubject: Rattle from around driver's rear wheel   Sun Aug 11, 2013 7:56 pm
Last night well after midnight (i.e., in the dark) I was on the way home on 125 in Haverhill, and hit a raised manhole that wasn't marked with my back wheel. It wasn't terrible or anything but is worth mentioning.  Also, a few days ago, I tried the parking brake on the car (this is the SS) and to my surprise it worked real good, I was thinking it wasn't the whole time. Laughing
Anyway, when I got to Andover on 125, I had my window down and noticed an annoying rattle sound coming from the driver's back side of the car, when the rear wheel on that side hits a bump. It also even does it a little over dips in the road, vibrations, etc.
Today when I was poking around, I found one of the bottom rear sway bar bolts on the D/S is just hanging down below the bar, loose, and spins. I think one of the welded on nuts inside the u-channel is broken off up in there, maybe from the bump I hit?  To try and isolate things though, i put duct tape over the loose bolt and drove around...the car still made the noise essentially the same.
I have to tear into things this week at some point, but I was wondering if there was a common problem with the rear brakes making a noise like this? It sounds like a metal nut being shaken around in a tin can.  I'm curious as to whether by applying the e-brake that I jogged something loose from it not being used, etc.
I checked the exh. heat sheild next to the fuel tank but that doesn't seem to be hitting anything or terribly loose (I know they're inherently flimsy...)
PostSubject: Re: Rattle from around driver's rear wheel   Sun Aug 11, 2013 8:23 pm
Is the sway bar loose now that the bolt is dangling?
On the same page, where did the welded nut go?
I'm not familiar with the rear sway bars so I can't picture it in my head.
If it was a drum rear I'd say yup you broke something mashing on the e-brake. But there's really not a whole lot to break on a disc rear.
How about putting the rear up on jack stands and have someone put it in gear and let the tires spin a little above idle while you listen?
Did you check the impala caps for a loose lug nut?
PostSubject: Re: Rattle from around driver's rear wheel   Sun Aug 11, 2013 8:28 pm
if it has the older style mount I almost want to think it's bouncing inside the control arm.
PostSubject: Re: Rattle from around driver's rear wheel   Sun Aug 11, 2013 8:30 pm
When you engage the rear e brake it pulls a lever that forces both pads out at the bottom to contact the drum.
There are 4 pc's there...the lever, 2 ends that contact the pads & a little rod that sits between them
If the pads arent installed properly (under thier respective retaining clips) the 3 parts inside the drum (all but the lever) can fall out into the inside.
CAN...but wont always...catch & scrape like a mofo. If THAT doesnt happen, they could just rattle.
Pull the tire & drum...you'll know instantly if that was it....when I bought my DD the guy didnt have drums installed but left the pieces there....until they dislodged.
PostSubject: Re: Rattle from around driver's rear wheel   Sun Aug 11, 2013 8:49 pm
Thanks guys-
I will look for a lugnut now but I don't think that could be it, otherwise it would be making noise all the time? I can be driving the car at high speed and there's no noise, but when I hit a bump, it rattles.
The sway bar does move if I go nuts banging on it or pulling down on it. But the rattle sounds like a lighter tinny noise where the sway bar sounds like someone slammed the lid to a grand piano down by comparison...Smile  I do need to fix that.
The way the setup on the car works is there is a u-channel bracket that goes up inside of the LCA where it's open underneath. Thread cutting bolts go in from the sides to lock the bracket in place. On the bottom of the bracket, that's where the sway bar mounts up against. Bolts go through the bar and bracket, and on the inside (up on top) of the bracket in the "U", there are 2 nuts tack welded in there that the bolt goes in. It's sort of chintzy. I have a whole new setup of all that stuff, bolts, etc. someplace in the attic including new GM brackets that I was going to use in the white Caprice.
The bolt going through the bottom of the sway bar is still there, and the nut or whatever it's in up above is still attached, but I can't pull it out of the assembly. It's gonna have to be cut off I think because you can't get a wrench up inside the LCA the way it's together (I don't think). I'll have a better idea when I'm on my back under the cah.
Thanks for the info on the rear brakes Steve, sounds kinda like the brakes on my Tahoe, except the truck ones were shitty and GM went back to drums for at least a few years on them, LOL. The caliper just unbolts in typical fashion I assume on this thing? I've never messed with these rear discs before, have to get a manual for this car...heh
PostSubject: Re: Rattle from around driver's rear wheel   Wed Aug 14, 2013 12:24 am
Just an update- I checked the lugs and they were fine (although thinking about it and guessing that if one did come off, it could rattle like that if centrifugal force held it in one spot at higher speeds). I put the car down in Malden so I can mess with it later this week, and the noise got WAY worse. It was a very loud rattle by the time I got off Route 1 and went down some badly paved surface roads, people were looking at me seeing what the noise was. I hope this means it will be easier to find. I forget if I mentioned it but applying the brakes doesn't change it, and I also applied the emergency brake a bit while rolling down a crappy street over bumps, and that affected it in no way either.
I'm guessing it's the sway bar coming loose. Have to dig out all my sway bar parts...I hope a cordless drill with a socket will get those thread cutting bolts in place so I can torque them.
PostSubject: Re: Rattle from around driver's rear wheel   Wed Aug 14, 2013 9:07 am
You got a visual on your shock mounts?
PostSubject: Re: Rattle from around driver's rear wheel   Wed Aug 14, 2013 9:27 am
For once i have to agree with the old fart.
PostSubject: Re: Rattle from around driver's rear wheel   Wed Aug 14, 2013 11:05 am
Dont make a habit of it...cuz it decreases my odds of being right
PostSubject: Re: Rattle from around driver's rear wheel   Wed Aug 14, 2013 12:50 pm
You'll forget all about this conversation my dinnertime anyway! Very Happy
PostSubject: Re: Rattle from around driver's rear wheel   Wed Aug 14, 2013 6:12 pm
Jeez, didn't think of those either, I'll check them tomorrow. I was there again today and wailed on the bar with a mallet, it does rattle, it just feels like the noise was more tinny than the solid bar would make. I can literally pull the bar down about 1/4 where the one bolt is loose. That loose bolt does hang down like a half inch and clang around, but I wasn't sure if that was the noise.
PostSubject: Re: Rattle from around driver's rear wheel   Wed Aug 14, 2013 9:40 pm
Check the upper control arm bushings too. I noticed the ones on my new mess of a wagon are gone and over the slightest bump it makes all kind of banging noises. Lift up the car by the control arm and try to move the wheel left/right and up/down.
PostSubject: Re: Rattle from around driver's rear wheel   Thu Aug 15, 2013 9:48 pm
I believe it's fixed....haha.
Pain in the ass job for what it was but that was the problem, the bar and the loose bolt were clanging around. The U-brackets have nuts (the look like they're made of copper or something scratch  ) tack welded in them.  The bolts come up from underneath and screw into those nuts.  The car had smaller bolts with little nuts added up on top and the brackets had seen better days, which I guess was the reason for the diff bolts and added nuts up on top/inside the arm.  That nut had come undone.
I'll prob. do the other side of the cah since I have the pahts, just didn't have time today.  I used grade 8 bolts, lock washahs, and flat washahs, kehds.  I also applied some blue Loctite on the threads.  The bolts turned out to be perfect length!  So glad I had all this stuff laying around, I'd lost it last year...
The thread cutting bolts are a pain to put in laying on your back, you really can't get them started by hand and I had to use a regular cordless DeWalt since I don't have an impact.  I almost burnt the thing out doing it, but it worked.  Torqued them all down to what I believe spec is according to what I've seen on ISSF.
We'll see what happens, all is pretty quiet now, aside from a slight tick from the rear on bumps that was there before and is hardly noticeable. If this car rode softer it probably wouldn't do it, probably the heat shield or something.
Not bad for someone who has no clue what he's doing I suppose.  afro
PostSubject: Re: Rattle from around driver's rear wheel   Fri Aug 16, 2013 3:15 pm
I like the brand on that Torque wrench lol
PostSubject: Re: Rattle from around driver's rear wheel   Fri Aug 16, 2013 3:42 pm
Haha, I know, s'a Craffffsmin tohhk rench, kehd. It's the old kind but works for me and it's got a lifetime warranty on it...the other kind of torque wrenches apparently do not although I like using those better.
PostSubject: Re: Rattle from around driver's rear wheel   Fri Aug 16, 2013 4:07 pm
Yes, it has a lifetime on it because it can only PHYSICALLY break....
Noone would ever doubt the percision torque settigs right?
PS: I cut off all the BS & use mine for a breaker bar..torques are over-rated anyway
PostSubject: Re: Rattle from around driver's rear wheel   Fri Aug 16, 2013 4:56 pm
Haha, I know, all it is is a spring, lol. I did notice it works as a nice breaker bar...
PostSubject: Re: Rattle from around driver's rear wheel   Sat Aug 17, 2013 1:13 pm
It works as a pretty decent hammer in a pinch too... Smile
PostSubject: Re: Rattle from around driver's rear wheel   Mon Aug 26, 2013 10:17 pm
Just a funny update to this, don't fiddle with your heat shields. I bent mine thinking initially that it was making the noise, and now it touches the tailpipe on that side and won't stay away. That POS is coming out tomorrow. I don't get why it even has the stupid thing there, there's 2 tailpipes and I don't recall seeing 2 on cars that had 2 pipes. Maybe the 9c1s did?
PostSubject: Re: Rattle from around driver's rear wheel   Mon Aug 26, 2013 11:23 pm
FWIW the heat shields on my RMW fell off years ago and it hasn't caught fire yet Cool
PostSubject: Re: Rattle from around driver's rear wheel   Mon Aug 26, 2013 11:31 pm
Every dual exhaust car had shields on both sides. If they were not there its because they fell off.
» Rear wheel vulcanising
» WTB: Fleetwood drivers rear wheel well chrome piece
» 1994 Caprice Classic Wagon For Sale/ Last Call B4 the Junkman cometh !
» 1996 Impala SS - LS Swap - 44,000 Original Miles
» RH Rear Wheel drive bosses
