Please tell me it's not the rear main.. EmptyWed Oct 19, 2022 1:27 pm by scot
Please tell me it's not the rear main.. EmptyTue Oct 18, 2022 8:58 pm by silverfox103
Please tell me it's not the rear main.. EmptyTue Sep 28, 2021 11:01 pm by silverfox103
Please tell me it's not the rear main.. EmptyFri Sep 24, 2021 9:53 am by ElKy
Please tell me it's not the rear main.. EmptySun Sep 19, 2021 6:22 pm by black blur 96
Please tell me it's not the rear main.. EmptySun Jun 20, 2021 11:37 am by scot
Please tell me it's not the rear main.. EmptyFri Jun 11, 2021 10:41 am by scot
Please tell me it's not the rear main.. EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
Please tell me it's not the rear main.. EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
7 posters
PostSubject: Please tell me it's not the rear main..   Please tell me it's not the rear main.. EmptySun Aug 11, 2013 10:32 pm
I still have to get under this car and look at it, but I wanted to get some input from you guys. I noticed on my 96 RMW that when you start it when it's cold oil will come out of the torque converter cover. It comes out in a stream for a few seconds and then stops completely. Again, I only see this when the engine is cold. Anyone ever see an LT1 do this? I figured a rear seal would constantly leak.
PostSubject: Re: Please tell me it's not the rear main..   Please tell me it's not the rear main.. EmptyMon Aug 12, 2013 6:58 am
When your engine and it's lubricating oil are cold, initial operating hydraulic oil pressure is at it's highest.
There are some plugs that are interference press fit into the cylinder block behind the flywheel.
www.chevyhiperformance.com/tech/engines_drivetrain/shortblock/83818_block_plug_basics/
Here you can find what the hidden back of your block looks like.
The large welch plug in the center for the cam and the three small ones over it at 10, 12 & 2 o'clock have engine oil behind them.
The other two large plugs are coolant.
You must also check the rear main one piece seal and it's housing for leaks.
Don't forget to check the very common oil pressure sender leak, left center behind intake manifold rear seal edge.
You did say engine oil, otherwise you should check the transmission front seal.
PostSubject: Re: Please tell me it's not the rear main..   Please tell me it's not the rear main.. EmptyMon Aug 12, 2013 7:40 am
Thanks, gonna check the oil sender hoping for a quick fix. If that or the intake gasket on the rear isn't the issue, I guess it's time for a trans pull. I caught some oil on a pan, it's definitely motor oil.
PostSubject: Re: Please tell me it's not the rear main..   Please tell me it's not the rear main.. EmptyTue Aug 13, 2013 7:50 am
Now it gets weird. I pulled the cover last night and first thing I noticed was a small hole punched in the cover towards the rear of it, nothing major. Once the cover comes out there's a 1" long threaded part of a broken bolt sitting in the pan! Looks to be 3/8", and I can't figure out where a bolt like this would normally be in that area.
Anyways, I cleaned it all off with brake clean (oil was splashed all over the bell housing and looks like it pooled enough for the flex plate teeth to sit in it) and started it back up. I don't see anything dripping from anywhere at all. The main looks dry even after running for a while. If the weather cooperates today I'll check it now that it's sat overnight.
PostSubject: Re: Please tell me it's not the rear main..   Please tell me it's not the rear main.. EmptyTue Aug 13, 2013 10:38 am
That is strange. I don't recall anything mounted in that area when I did the trans swap. I know the inspection cover has a drain/weep hole in it. Not sure what you mean by a hole "punched" in it.
Non really related, but I have a buddy with a lowered car and he got a trailer hitch ball through his oil pan on 95. What a mess!
PostSubject: Re: Please tell me it's not the rear main..   Please tell me it's not the rear main.. EmptyTue Aug 13, 2013 1:35 pm
Damn that must suck! I can't think of what this could be from, I don't think there's anything in that area. My guess is someone did a trans swap and this was left there? I'll take a pic of the hole later, I think it was the bolt getting kicked up by the flex plate and getting thrown.
PostSubject: Re: Please tell me it's not the rear main..   Please tell me it's not the rear main.. EmptyTue Aug 13, 2013 8:51 pm
So you think that oil was just sitting in there a while and now it's gone from when you looked into it? Forgive my ignorance but I'm assuming oil would be introduced because of the input shaft or something? I thought it was motor oil leaking?
PostSubject: Re: Please tell me it's not the rear main..   Please tell me it's not the rear main.. EmptyTue Aug 13, 2013 10:02 pm
I've got an lt1 on am engine stand and I don't see anything back there that could have broken off.
The only thing I can think of is the rear seal housing, but it's small bolts and they really can't come out unless you remove the flexplate.
PostSubject: Re: Please tell me it's not the rear main..   Please tell me it's not the rear main.. EmptyWed Aug 14, 2013 7:57 am
It is motor oil for sure, but I don't see where it was coming from. I checked again this morning after starting it and it's still dry.
This is a 3/8" bolt, no idea how it got there.
PostSubject: Re: Please tell me it's not the rear main..   Please tell me it's not the rear main.. EmptyWed Aug 14, 2013 9:33 pm
Looks like I narrowed down to the oil filter adapter! cheers
I noticed some oil dripping onto the driver's cat if I don't put the cover back on, with the cover on it must be catching the drips. That's a relief, I'd much rather do that job than pull a trans! Thanks for the suggestions guys.
PostSubject: Re: Please tell me it's not the rear main..   Please tell me it's not the rear main.. EmptyThu Aug 15, 2013 10:49 am
Yeah but where did the bolt come from. Laughing
PostSubject: Re: Please tell me it's not the rear main..   Please tell me it's not the rear main.. EmptyThu Aug 15, 2013 3:10 pm
Prior owner wedged the bolt in between the cover & case so the oil wouldnt collect...badass mod #645
PostSubject: Re: Please tell me it's not the rear main..   Please tell me it's not the rear main.. EmptyThu Aug 15, 2013 4:43 pm
I like that one, I'm going with it Very Happy
» Question on rear main seal... LT1 guru's this is for YOU
» Need a rear defroster clip, rear wiper, cargo light switch
» Can I aks youse a kwesshion about uh spun main bearing, yo?
» WTB Rear end
» 4.10 gears
