| Next question regarding my dimmer switch issue | |
| Subject: Next question regarding my dimmer switch issue Thu Jul 11, 2013 2:10 am | |
| Since the connector tabs from the harness to the dimmer switch are melted away, the connector popped out of the new switch when I left work tonight.
When I reached down to plug it back in, my fingers were INSTANTLY burned. This is less than 5 minutes of having the headlights (low beams) on.
When I got home, I noticed that: 1) the connector is waaaay to hot to touch 2) there's at least 1 semi exposed wire at the connector 3) insulation is blackened at the connector 4) following the harness from the connector/dimmer, up into the conduit where it joins the main harness, the wires are HOT!!!
Headlights work fine tho. No issues at all. Hi/lo operates normal.
What could be causing this condition?
I'm going to look into some key on, lights off/on tests tm as well as double check proper amp fuses.
Everything in the actual headlight harness is stock except the addition of the other 2 note horns.
I'm sure that this is what led up to the demise of the original switch.
Previously I had 6000k HIDs (last summer) but now have 9004 silverstars, and I had the smaller corner parking lamps swapped out to larger 1157s. Those are now back to stock.
Any ideas or suggestions? | |
| Subject: Re: Next question regarding my dimmer switch issue Thu Jul 11, 2013 7:54 am | |
| I bet there's a lot of carbon on the contacts from it burning up the first time causing a ton of resistance. Your best bet is to cut a connector out of a junkyard car and splice it in. Rockauto appears to sell every one of those connectors except the one you need. | |
| Subject: Re: Next question regarding my dimmer switch issue Thu Jul 11, 2013 9:10 am | |
| One step ahead of you Dave. I already ordered a new connector and pigtail from advance. $29. Id rather have new over used as far as this is concerned. Gotta be replaced anyway.
Any idea where to get the proper blade terminals so I can repin the connector? I don't want to reuse the terminals and I'd like to cut away the exposed and burned portion.
I'm on board with the resistance from being melted.
What makes you think it won't melt again? Wondering, could the dimmer cause it to melt? And now I have a separate heat/resistance issue due to the melted junk? | |
| Subject: Re: Next question regarding my dimmer switch issue Thu Jul 11, 2013 10:38 am | |
| In my experience, when it gets to the melting point, you have a short
I hate to say it cuz it could be a bitch but I'd buzz out those wires
Unhook the battery & check continuity and resistance of each wire to ground & to other wires in that connector....you'll find the problem
If you do it using the terminals 1st (before you cut off the connector), you might prove your short is right there....saves time
DONT screw with that....it has flambe written ALL OVER IT | |
| Subject: Re: Next question regarding my dimmer switch issue Thu Jul 11, 2013 11:51 am | |
| I'm no electrical genius, what are the specs? | |
| Subject: Re: Next question regarding my dimmer switch issue Thu Jul 11, 2013 12:19 pm | |
| I know, I know. "Don't throw parts at it".
I just ordered Gary's innovative headlight harness to help alleviate some of the stress put on the almost 20 year old, shabby stock wiring.
I figure I'll order the battery cables next. | |
| Subject: Re: Next question regarding my dimmer switch issue Thu Jul 11, 2013 2:17 pm | |
| - MASShole9C1 wrote:
- I'm no electrical genius, what are the specs?
No specs...really Set your meter on resistance (usually a little picture of a chime) so when you touch the leads together the meter beeps All your doing is checking that each wire is un compromised from 1 end to the other Touch 1 end with 1 lead & the other with the 2nd lead....BEEP = 1 complete wire (not broken ) For example, if the insulation wore off from rubbing against a metal edge, when you touch 1 end with 1 lead & ground with the 2nd lead...BEEP = wire shorted to ground (no good unless its a ground wire) Also you go from wire to wire to make sure they havent melted together You'll still want to do this to the harness you dont replace | |
| Subject: Re: Next question regarding my dimmer switch issue Thu Jul 11, 2013 2:22 pm | |
| Sounds good. Thanks Steve! | |
| Subject: Re: Next question regarding my dimmer switch issue | |
