March 2018
 Grinding noise while turning left
PostSubject: Grinding noise while turning left   Wed Jul 03, 2013 5:51 pm
Hey guys, need some help with my 86 C10. When I turn left at speed (above 10 mph), I hear a grinding noise coming from the right front. Also get a vibration from that side. I'm thinking its a wheel bearing, they look and feel ok but the inner bearing is loose inside the rotor. I don't think it's supposed to be like that, right?
If one of you guys could help me with this, I would appreciate it. Thanks
PostSubject: Re: Grinding noise while turning left   Fri Jul 05, 2013 12:16 pm
The bearing is certainly supposed to fit perfectly with the race when the rotor goes on the spindle.
The inner seal keeps the bearing from pulling out (easily) but when you seat the rotor there shouldnt be any play
Just from the way you describe it, I cant tell
95 Black WB4
95BBB 189K 3.08 Old DD Matt. Cool
» Car Pulls To The Left/Clunking Noise
» noise in power amp
» Right channel does not sound nearly as loud as the left
» Albino turning red - internal infection?
» power switch noise
