» Mass refugee now in Pa
» 1996 DGM RMW
» Roundup pics?
» Looking for exhaust part
February 2019
 94 to 96 9C1 rear end into a 84 Impala
1A2 Service Wagon
PostSubject: 94 to 96 9C1 rear end into a 84 Impala   Thu Jun 27, 2013 10:07 pm
Hello guys. I just installed a complete rear end from a 95 9C1 into my 1984 Impala. (In fact I installed the complete front/rear suspension into it). As suspected it went in without any issues. However I can't seem to find a set of emergency brake cables that will work. I though I could simply install a set for a 95 9C1...but they are too long. Anyone run into this problem? And if yes what was your solution?
Thanks in advance.
PostSubject: Re: 94 to 96 9C1 rear end into a 84 Impala   Thu Jun 27, 2013 10:47 pm
I'll take some of those blue interior parts you have from Andrew for an answer to your question Wink
JK. Matt (1984twodoor) I believe would have your answer. As he is installing an ss rear into his 87 restoration. It might be in his thread. But, why bother search, right??
PostSubject: Re: 94 to 96 9C1 rear end into a 84 Impala   Fri Jun 28, 2013 10:00 am
Did you adjust it out all the way?
PostSubject: Re: 94 to 96 9C1 rear end into a 84 Impala   Fri Jun 28, 2013 12:52 pm
Why would anyone do that, your always so eager to help! Cool
PostSubject: Re: 94 to 96 9C1 rear end into a 84 Impala   Fri Jun 28, 2013 3:06 pm
....in and out
....face palm
1A2 Service Wagon
PostSubject: Thanks for the replies   Sat Jun 29, 2013 10:32 am
Yes its adjusted all the way...the difference in length is over half a foot not something that could be compensated by adjustment.
I did try the search function...and it did not turn up anything of value. That's why I then asked the question. I don't know about other people on here, but time is not something that I have an abundance of...this is why I find it best to ask a direct question and hope for a direct answer.
Thanks
PostSubject: Re: 94 to 96 9C1 rear end into a 84 Impala   Sat Jun 29, 2013 1:15 pm
I think Matts away on vacation or something
He probably HAS looked into this as he's installing an impala rear.
Hang tight & he'll help I know
PostSubject: Re: 94 to 96 9C1 rear end into a 84 Impala   Sun Jun 30, 2013 11:55 am
I figured I could just use the cables like he did. Now we are both searching I guess. I really wasn't concerned with cables at this point in time. I really just need body on frame and frame completion before the little $hit starts.
Back from vaca now btw
1A2 Service Wagon
PostSubject: Up Date   Tue Jul 16, 2013 7:40 pm
Well, I figured it out. You need to get the "link" from the newer car. In my case I used one from a 95 Buick Roadmaster. I don't have any pictures yet, however I will get some and post them. In the end, all of the parts from the 94 to 96 9C1/SS swapped over just fine.
» Need a rear defroster clip, rear wiper, cargo light switch
» 1996 Impala SS - LS Swap - 44,000 Original Miles
» GN rear window mod
» Rear end Gear ratio's?
» F/S new G body rear springs
