94 95 96 lt1 interchange harness/pcm EmptyWed Oct 19, 2022 1:27 pm by scot
94 95 96 lt1 interchange harness/pcm EmptyTue Oct 18, 2022 8:58 pm by silverfox103
94 95 96 lt1 interchange harness/pcm EmptyTue Sep 28, 2021 11:01 pm by silverfox103
94 95 96 lt1 interchange harness/pcm EmptyFri Sep 24, 2021 9:53 am by ElKy
94 95 96 lt1 interchange harness/pcm EmptySun Sep 19, 2021 6:22 pm by black blur 96
94 95 96 lt1 interchange harness/pcm EmptySun Jun 20, 2021 11:37 am by scot
94 95 96 lt1 interchange harness/pcm EmptyFri Jun 11, 2021 10:41 am by scot
94 95 96 lt1 interchange harness/pcm EmptyWed Jun 09, 2021 9:41 pm by Chris Klein
94 95 96 lt1 interchange harness/pcm EmptyWed Jun 02, 2021 9:02 pm by Chris Klein
2 posters
PostSubject: 94 95 96 lt1 interchange harness/pcm   94 95 96 lt1 interchange harness/pcm EmptySun May 26, 2013 3:04 am
I have a 96 engine and 4l60e that I want to run as an obd1 (94/95) setup.
I also have a 94 harness and PCM.
I understand OBD ports, and knock sensors need swapping also. But is it as simple as that?
Will the PCM just ignore the CPS? what about transmission lock up?
I guess I'm doing all this to avoid tuning the PCM so I can add headers, delete cats, delete EGR, etc.
So if it's gonna end at getting a tune anyway I'm not gonna bother. Just seeing what I CAN do with what I do have.
Also possibly willing to trade a 96 lt1 for a big block chevy engine if anyone has one laying around. Any displacement 396, 402, 427, 454. Long block would be nice accessories not necessary.
Thinking about temporary 55 caddy drivetrain until I can restore the original frame and engine ($$$$)
Everyone says 472/500 but unless it's a 1970 or 71 why bother? Expensive to buy parts for to get big HP.
The lt1 would push her along fine (only a little less power than the stock 331) but I'd be more comfortable with a BBC pullin her.
Bull
Bull
PostSubject: Re: 94 95 96 lt1 interchange harness/pcm   94 95 96 lt1 interchange harness/pcm EmptyTue Jul 02, 2013 11:11 pm
Check out this thread; makes it sound pretty simple.
http://www.impalassforum.com/vBulletin/showthread.php?t=265130
Did you end up using that motor?
» transmission interchange
» Parts Interchange
» Hollander Parts Interchange Info
» Harness wanted
» New Opti harness
